Re: small block overheating
[Re: hemiparts]
#520085
11/08/09 11:03 PM
11/08/09 11:03 PM
Posts: 1,532 off the grid
340B5
off the grid
If its the Moroso pump drive, yes, very possible. It pumps 8.8gpm w/standard drive pulley and 11.3gpm w/ the 28% OD pulley. You might try an extra fan. Also, (please forgive) but where do you get the blue headlights/covers or whatever.
Yeah, it's got a smallblock.
[Re: chris3]
#520095
11/09/09 10:46 AM
11/09/09 10:46 AM
340B5
off the grid
A couple things I've tried on mine were to enrich idle mixture(but not so much you're cleaning plugs the first 330') and idle as slow as possible. Backing off initial timing could help if your engine combo would allow it.
[Re: chris3]
#520096
11/09/09 10:49 AM
11/09/09 10:49 AM
Posts: 7,506 Az
Crizila
Az
I'm open to any suggestions on the overheating, thanks.
The announcer at the track yesterday called it the "blue-eyed Duster." Sox painted those lens blue for years. Clean the light, degrease it and spray with Candy Blue paint. The paint has to be candy top coat or it will be too thick. Then buff it like buffing candy paint.
That picture Hemiparts has at the beginning is priceless. When I have those guys, my son and my two grandsons, all at the track it is a good day if that car runs good or not. That little guy, standing on the cooler, is bound to have 114 as blood.
With out a doubt - " priceless!" To visually check flow, run it with the cap off. You should see lots of coolant movement accross the fill neck hole. To make sure you don't have any radiator blockage, run your hand accross the front of the entire core area. It should be hot everywhere.
Fastest 300
[Re: hemiparts]
#520098
11/09/09 11:18 AM
11/09/09 11:18 AM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
It might be a circulation problem..Every heating issue I have ever had with a big block was the radiator. Those engines just dont run hot. The Moroso pump while not the best thing on the market does the job at the track. Inspect the cooling system carefully.
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
