B1 head question #520036
11/08/09 09:23 PM
11/08/09 09:23 PM
Pa.
BENCHRACER Offline OP
"Little Stroker"
"Little Stroker"
Pa.
I never messed with B1's....are some better than others (B1BS etc.)
DUSTER44T
Re: B1 head question [Re: BENCHRACER] #520037
11/08/09 09:34 PM
11/08/09 09:34 PM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
The order from most airflow to least. B1-TS, B1 Original, B1-BS. Cost follows the same order.
Joe
Without Data, you’re just another guy with an opinion.
Re: B1 head question [Re: BENCHRACER] #520038
11/08/09 09:48 PM
11/08/09 09:48 PM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
the bs will flow 325int[i believe] as sold basic ready to go with no rockers as per the b1heads.com
Re: B1 head question [Re: sr4440] #520039
11/08/09 10:05 PM
11/08/09 10:05 PM
Quebec, Canada
Diablo Offline
Diablo  Offline
Quebec, Canada
Joe
Forgot two
B1-TS, B-1 PSO, B-1 M/C, B-1 Original, B-1 BS
Ill guess the flows
TS= 500+++
PSO=480
MC=450
Orig=400
BS=350
Re: B1 head question [Re: Diablo] #520040
11/09/09 06:14 PM
11/09/09 06:14 PM
Gearbox Offline
Gearbox  Offline
Hey Diablo
Sounds like you may have a couple sets of B-1's under the work bench....Will the B1MC work on a stock 400 block with B1 Pistons, or just original B1's and B1 B/S versions.
Re: B1 head question [Re: Gearbox] #520041
11/09/09 06:51 PM
11/09/09 06:51 PM
sg66mopar Offline
sg66mopar  Offline
The B1 MCs require a 4.5" bore.
Re: B1 head question [Re: Gearbox] #520042
11/09/09 06:52 PM
11/09/09 06:52 PM
Quebec, Canada
Diablo Offline
Diablo  Offline
Quebec, Canada
The MC head will work on a stock block. But i'm pretty sure you need a min bore of 4.500. (which i guess rules out a stock block)I also think the MC's need pistons cut a bit different than the original B-1's.
The only B1 heads i have right now are the ones on our 636 engine which are the B1-TS heads. Although i think the B1 heads are the best out there for choice and quality
Re: B1 head question [Re: Diablo] #520043
11/09/09 09:00 PM
11/09/09 09:00 PM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
Joe
Forgot two
Ill guess the flows
TS= 500+++
PSO=480
MC=450
Orig=400
BS=350
doh!
Joe
