1966 904 Intercooler? #519926
11/08/09 08:06 PM
11/08/09 08:06 PM
California
darkrider2 Offline OP
California
My buddy has got a 1966 valiant with a slant six and a 904(I think). The thing is that it has two sets of trans cooler lines , one set that goes into the bottom of the radiator, and the other set is an actual trans cooler that mounts up next to the radiator Anybody know why there would be two trans cooler lines for a slant six 904 or if they are even necessary???
Re: 1966 904 Intercooler? [Re: darkrider2] #519927
11/08/09 09:04 PM
11/08/09 09:04 PM
RapidRobert Online content
RapidRobert  Online Content
Is this one plumbed in series w the oe one in the bottom tank of the rad?. If so it's an aftermarket addition for more cooler area, always a good idea. yes it's a 904
Re: 1966 904 Intercooler? [Re: RapidRobert] #519928
11/08/09 09:28 PM
11/08/09 09:28 PM
California
California
See thats the thing it looks like both sets of lines go back to the trans.
Re: 1966 904 Intercooler? [Re: darkrider2] #519929
11/08/09 09:30 PM
11/08/09 09:30 PM
How are they plumbed there (at the trans) EDIT dont tell me that each cooler fitting at the trans has a T and the fluid is going out to the coolers in parallel instead of series . MORE EDIT The orifice in the trans case would be the same dia including the ID from there to (& including) the T fitting so there would be no increased flow. Best would be to plumb em in series or if starting from scratch to drill out the case for a larger ID fitting & use the next size larger (3/8 I think) tranny lines and an aftermarket cooler w larger fittings for 3/8 lines & not use the oe bottom tank cooler at all expecially as I like to keep the ATF far away from the coolant and myself I dont think the trany fluid needs to be warmed up from the coolant. All a moot point w a /6 just thinking out loud
Re: 1966 904 Intercooler? [Re: RapidRobert] #519930
11/09/09 02:39 AM
11/09/09 02:39 AM
California
California
Thanks of the advise Robert
PS hope that carb worked out for you
