440 street/strip build #519905
11/08/09 07:50 PM
11/08/09 07:50 PM
Home of the Bluegrass
MoparJunkie Offline OP
Hey guys, little help here.... I am building a 446, and I want to keep my 71 steel crank and rods. Any suggestions on a piston, head, cam combo that will get me 525-550 hp. Wanna be able to do mostly street and occasional strip runs. Want the best combo to achieve this.... 73 Cuda with 4 speed and 3.91 gear
Thanks in advance
GG
Plus I heard the engine guru's hung here! LOL
"It takes a Mopar to catch a Mopar”
1971 Roadrunner FJ6 Sassy Grass 505"RB, 18 spline 4 speed, and Dana 60 with 3.54
2022 Hellcat Charger Widebody Redeye Jailbreak: Hellraisin with 8 speed auto
Re: 440 street/strip build [Re: MoparJunkie] #519906
11/08/09 08:00 PM
11/08/09 08:00 PM
Canada
CrAzYMoPaRGuY Offline
Canada
Thanks in advance
GG
I have a 446ci Jensen made for street/strip, I went with a 270 Comp cam, milled and ported heads with valve bowl work, 9.35 to 1 compression, two Edelbrock 500 carbs and Delta Motorsports headers.
I have a feeling I'll be more like 400hp than 500hp though...
To be honest in your situation I would look at a 4.15 stroker crank...?
CrAzYMoPaRGuY
Re: 440 street/strip build [Re: MoparJunkie] #519907
11/08/09 08:09 PM
11/08/09 08:09 PM
Thanks in advance
GG
Naw, somebody is lying to you, none of the engine gurus on here,myself included, are hung Not that any of the girls are telling about anyways Now, to the moe seriuos matters on how to make HP with a 446, start with a new set of good aluminum heads like the Eddy RPM heads, a set of forged lightweight aftermarket flat top piston with valve releifs(not a heavy set of Speed Pro or TRW six pak or flat top forged pistons) and a camshaft type(solid or hydraulic, roller lifters or flat type lifters, depending on your budget restraints) that you want. I like Comp Cams brand and use them almost exclusivily now in my engines with your car, trans and gear ratio I would (with headers) probally use the XE-HL grinds, either the XE285HL or the XE295HL hydraulic lifter grinds or a XS290S soild lifter cam. If you want a rollere cam then you will have to make a decision on the type of roller lifter, solid or hydraulic and type of grind on the solid foller cam, street and strip or race cam. Race cams not recommended by me for street and strip use, they are to hard on parts for the average street strip racers BTW, are you going to use a six pak set up on the car ? I do IHTHs.
Re: 440 street/strip build [Re: Cab_Burge] #519908
11/08/09 08:36 PM
11/08/09 08:36 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
I agree with Cab, just basic stuff, good machining and assembly with get you there. I'm doing the same build right now: 040" over 440, Wiseco (light) flat tops, stock stroke, etc. Cam to be determined based on what it goes in, but no more than 260-ish either roller or solid. CR will be at least 11:1 with some form of OEM type aluminum head; either MP, Eddy or 440source. Holley SD or M1 and 850-950-ish of carb. Should fall right into your range of 525-550...although I want TORQUE, too...hopefully in the 575 ft lbs area!!
Re: 440 street/strip build [Re: cudadoug] #519909
11/08/09 08:56 PM
11/08/09 08:56 PM
Thanks guys.... If I go with the xe295hl cam anything special needed done? Adj rockers, shaft spacers or anything like that? Think I am going with the MP stage six heads....
Re: 440 street/strip build [Re: MoparJunkie] #519910
11/08/09 09:27 PM
11/08/09 09:27 PM
Any time you want to rev the motor higher than 4500 RPM you should have a decent set of adjustable rockers and good push rods to match the rocker adjuster sizes, the other thing is when you deck the block and add aftermarket cylinder heads or cut the heads to blueprint them you will need a adjsutable rocker arm or adjustable pushrods to set the preload or valve lash on the Hi Po cams being used today Buy the best parts you can get for the application, cheap parts can kill you
Re: 440 street/strip build [Re: Cab_Burge] #519911
11/08/09 09:31 PM
11/08/09 09:31 PM
What rockers and push rods do you recommend?
Re: 440 street/strip build [Re: MoparJunkie] #519912
11/08/09 11:23 PM
11/08/09 11:23 PM
A good set of ductile iron rockers for the flat tappet cams(soild and hydraulic tappet) and a good set(Harland,Sharp,T&D,or Jesel) aluminum roller rockers for the solid roller lifter cams. As far as pushrods either Smith Bros or Mantons(the best ) in the proper thickness for the valve spring pressures and RPM
Re: 440 street/strip build [Re: Cab_Burge] #519913
11/09/09 12:09 AM
11/09/09 12:09 AM
Central Valley, CA.
Quicksilver440 Offline
Central Valley, CA.
Re: 440 street/strip build [Re: Quicksilver440] #519914
11/09/09 06:40 AM
11/09/09 06:40 AM
Utah
topbrent Offline
topbrent  Offline
Utah
CarCraft did a nice buildup article on a 540-hp / 580-tq 440 a few years back.
Great easy to build (and live with) street stump puller.
Also, note the similarities and common theme.
This combo uses many of the same basic parts and advice others have already recommended to you in this post.
If it were my build, I definitely would use a solid lifter cam for the increase RPM capability.
You are halfway there with adjustable rocker gear...why not take further advantage of the capabilities of a solid cam also?
Why risk the BS of valve instability and float with a Hydraulic cam.
Comp's MH, FL and SQ lobes are excellent and will live a long and happy life with a mopar .904 lifter.
Something comparable to the XE275HL in a solid would be FL272/FL276 lobes. 243/247 @050
CarCraft build:
RPM intake (stock)
RPM heads (stock)
Comp XE275HL cam 231/237 @.050
1.6 roller rockers
1" 4-hole spacer
750 Demon
Speedpro 2355f flattop sixpack pistons,
10.2 compression
LY rods
factory forged crank
2" headers
http://www.carcraft.com/techarticles/116_0205_mopar_440_update/index.html
Re: 440 street/strip build [Re: MoparJunkie] #519915
11/09/09 08:02 AM
11/09/09 08:02 AM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
Here's what I'm building which is a duplicate of a combo we ran years ago and I'm recycling some of the parts from that engine....
440 +.030 using flat top slugs- 9.7 compression
452 heads that have been ported and using the larger valves
Mopar 296/557 cam
750 Holley
Edelbrock TM-7
2" headers.
When the funds allow it,I will switch to Edelbrock heads.
It went 11.30's in a 71 Demon with a race converter and too much gear.I think 383 man has basically the same engine in a 63 Plymouth and his runs very well too.
Nautilus Racing-
Re: 440 street/strip build [Re: Quicksilver440] #519916
11/09/09 09:44 AM
11/09/09 09:44 AM
Will I need to use adj rockers if I deck the block to get the proper quench???? And, yes I am using a xe285-295hl cam(hyd flat tappet).
Re: 440 street/strip build [Re: MoparJunkie] #519917
11/09/09 09:59 AM
11/09/09 09:59 AM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
Most definitly!!
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
Re: 440 street/strip build [Re: joedust451] #519918
11/09/09 10:10 AM
11/09/09 10:10 AM
What brand of adj. rockers?
Re: 440 street/strip build [Re: MoparJunkie] #519919
11/09/09 10:27 AM
11/09/09 10:27 AM
South Carolina, United States
carolinacuda Offline
Your in the same boat I was in. In my 74 cuda I have a 446 with stock rods and crank. I use the 2355 trw pistons. I have a hughes solid 572/579 cam with a victor int topped with a demon 850. The heads are Indy EZ's stock port(I got them for their HP potential). Hooker comp headers. 28 MT ET's out back with 3.91 gears. I used to run a comp XE295HL cam and i liked it but i wanted more top end so changed to solid. I run 11.50's now and with the old Comp HL cam I was 11.70's. Both cams are good on the street. I still run power brakes also! All stock suspension and even old air shocks out back. Plenty left in it im sure. I use Indy's rockers and pushrods even though i dont recommend those rods!! I have replaced two of them so far. Good luck!
Re: 440 street/strip build [Re: carolinacuda] #519920
11/09/09 12:35 PM
11/09/09 12:35 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I recommend and after market rod they are inexpensive now and when you take in R and R of stock rods, they need new ATP rod bolts and re sizing, should be shot peened and maybe polished it is more than a new set of rods and they are floating easy on easy off pistons!
Re: 440 street/strip build [Re: Chris2581] #519921
11/10/09 12:18 AM
11/10/09 12:18 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Mopar 296/557 cam
750 Holley
Edelbrock TM-7
2" headers.
Yes my combo is almost the same in my 63 but I use 906 heads and the Holley Street Dominator intake. 850 DP and Hedman 1-3/4 headers. 11.52 is my best but I ran 11.50's the last 2 times out in the heat so I am hoping for 11.40's in the cooler air soon. I also use Isky ductile iron adjustable rockers that have worked fine. I like this simple combo as its a stock bottom end 440 with factory heads but at .030 it has 446 cubes. So it shows you can run mid 11's in a 3700 lb car with a basically stock eng internally other then a mild cam and pistons at the factory rating of 10.0 comp. Ron
Re: 440 street/strip build [Re: 383man] #519922
11/10/09 04:42 AM
11/10/09 04:42 AM
robin hood country
deaks Offline
deaks  Offline
robin hood country
This was my combo before it blew up,
440 .030 over
Trw six pack replacements
stock rods
Crane R280 Roller cam ( too big ) a better choice would have been something about .260 at 50
Isky rockers
cnc ported RPM's milled .050
Comp, just over 11-1
