So long as the end result is that you have the correct gap of "X" it doesn't matter if you are starting with 4.060 or 4.070. But I think it you try, there will be too much end gap using a 4.06 ring in a 4.070 bore. Not to mention the tension might be a little lighter. That may be a good thing in a race engine... I always use the .005" larger ring.
