Do I need specail antifreeze w/aluminum radiator ? #519874
11/08/09 07:43 PM
11/08/09 07:43 PM
Lyons, CO
MileHighDart Offline OP
Lyons, CO
Seems I've heard something about using a special antifreeze or using some kind of additive with your antifreeze to fight corrosion of aluminum parts in your cooling system mainly the radiator.
Is there something special to use, or am I OK with regular antifreeze? Just installed a new aluminum radiator and I want it to last.
Thanks,
Scott
Re: Do I need specail antifreeze w/aluminum radiator ? [Re: MileHighDart] #519875
11/08/09 07:45 PM
11/08/09 07:45 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I installed an aftermarket aluminum radiator two years ago and used regular antifreeze. Last week when I drained it out and looked down the side tank it all looked perfectly clean inside from what I could see.
Re: Do I need specail antifreeze w/aluminum radiator ? [Re: MileHighDart] #519876
11/08/09 08:05 PM
11/08/09 08:05 PM
Canada
CrAzYMoPaRGuY Offline
Canada
What about a rad cap with a built in sacrificial anode?
Cheap, and takes a little worry out of the whole situation IMO...?
CrAzYMoPaRGuY
Re: Do I need specail antifreeze w/aluminum radiator ? [Re: MileHighDart] #519877
11/08/09 08:21 PM
11/08/09 08:21 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Thanks,
Scott
Modern green (and any color) antifreeze has properties to handle aluminum. Since you are adding a lot of fresh surface area you might want to add a supplemental coolant additive like Justice Brothers Radiator protectant. Just extra precaution.
Re: Do I need specail antifreeze w/aluminum radiator ? [Re: autoxcuda] #519878
11/08/09 09:33 PM
11/08/09 09:33 PM
name brand good ole green, distilled water & a sacrificial anode screwed into an unused cooling port (they're cheap) plus you'll need it when you spring for some aluminum heads
Re: Do I need specail antifreeze w/aluminum radiator ? [Re: MileHighDart] #519879
11/09/09 02:31 AM
11/09/09 02:31 AM
Santa Cruz, California
Lefty Offline
Lefty  Offline
50/50 mix of G05 and distilled water works great in aluminum rads.
http://www.valvoline.com/products/brands/zerex/antifreeze/42
Re: Do I need specail antifreeze w/aluminum radiator ? [Re: Lefty] #519880
11/09/09 03:36 AM
11/09/09 03:36 AM
Detroit, MI
CokeBottleKid Offline
Detroit, MI
I tried that crap, seeped out of the head gaskets and water pump housing... no thanks. Went with the green stuff and was much happier.
Re: Do I need specail antifreeze w/aluminum radiator ? [Re: CokeBottleKid] #519881
11/09/09 04:44 PM
11/09/09 04:44 PM
Lefty Offline
Lefty  Offline
That had nothing to do with the antifreeze. Time to do some maintenance on your "crap" cooling system. It's what ma Mopar uses and recommends.
Re: Do I need specail antifreeze w/aluminum radiator ? [Re: Lefty] #519882
11/10/09 04:38 PM
11/10/09 04:38 PM
Detroit, MI
Detroit, MI
Funny, all the problems went away when I swapped.
Re: Do I need specail antifreeze w/aluminum radiator ? [Re: MileHighDart] #519883
11/10/09 06:24 PM
11/10/09 06:24 PM
DE
Ply72rr Offline
Ply72rr  Offline
DE
Re: Do I need specail antifreeze w/aluminum radiator ? [Re: Ply72rr] #519884
11/10/09 06:32 PM
11/10/09 06:32 PM
Radiator cap with sacrificial anode
that cap uses magnesium. The ones that screw into a cooling port were zinc. Will magnesium work just as good?
