Re: porting 596 small block heads ?
[Re: S/ST 3040]
#519837
11/09/09 09:58 AM
11/09/09 09:58 AM
Posts: 1,163 Newark, OH
Hunted Duck
Newark, OH
What is the current engine/tranmission/gear combination?
I can answer that question. Stock stroke 340 with je flat top pistons 0 decked. .560/.580 crane that is .258/.268 @.050. 1 3/4 hooker super comps. victor 340 intake that I did work to. 750 carb on E85. 4.56 gear 727 w/brake. 8 inch convertor that currently flashes arond 4500 with a stock 340. 99 rollout tires. car weights around 2950 with him in it.
[Re: S/ST 3040]
#519840
11/09/09 10:50 AM
11/09/09 10:50 AM
Hunted Duck
Newark, OH
That thing doesn't run bad for the converter, gear and tire combination. E-85 throws me but, it must share some of methanol's torque building characteristics??
Porting the heads will definitely pick it up. What valves?
Yes the E-85 does pick up the torque. His 60 fts picked up about 6 or so when the switch was made. I believe he has a set of 2.02 1.60 valves. 3/8 stem. Ferra I believe. He has a set of heads someone ported for him but the never did perform like he hoped and now are spraying water after only running for about 150 passes.
