Total Seal Piston rings #519785
11/08/09 07:03 PM
11/08/09 07:03 PM
Vitoria, Spain
Coke Offline OP
Coke  Offline OP
Vitoria, Spain
Good day,
I need to order a set of piston rings for my 440 0.30 over.
Somebody suggested to me the Total Seal rings but the Part# offered by 440 source for the 0.30 over engines (CR 6490-35) seems to be 0.35 over so i don,t know if it will be very much¿?
In the summit page there is another Part# available (CR 6490-30) wich i suppouse that will be 0.30.This one is not "File fit" like the other one
Does know somebody wich would go better?
Are the file fit rings better?
Thanks in advance for the help
Re: Total Seal Piston rings [Re: Coke] #519786
11/08/09 07:29 PM
11/08/09 07:29 PM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
the Part# offered by 440 source for the 0.30 over engines (CR 6490-35) seems to be 0.35 over so...
This ring set is for blocks bored .030 and then you file fit them.
Re: Total Seal Piston rings [Re: Commando1] #519787
11/08/09 09:28 PM
11/08/09 09:28 PM
I have not used them (yet) but it sounds like a good concept. My chebby dyno man says that they do not make any more power than regular (non total seal) ones on the dyno. The regular (non total seal) file fit (.005" OS) rings decrease the gap .0157 (C=Pi x dia). I go with .004 per inch of bore on top rings and .003" per inch of bore on 2nd rings and KB pistons require .006" (or more depending on the app) top ring gap per inch of bore so the more $$$ file fit rings are not needed & if the 2nd ring falls close to .003 per inch of bore using a non .005 OS set you're good.
Re: Total Seal Piston rings [Re: RapidRobert] #519788
11/08/09 10:56 PM
11/08/09 10:56 PM
North East Missouri
E
express Offline
express  Offline
E
North East Missouri
I run Total Seal Gapless rings in my 340 Duster. I use the file to fit rings to get the end gap I need. I have had good luck with them & would recommend them.
cny25421@centurytel.net 70 Duster Turbo Charged 79 Lil Red Express Bonded Locksmith
Re: Total Seal Piston rings [Re: express] #519789
11/08/09 11:43 PM
11/08/09 11:43 PM
I'm confused. I thought the total seal rings were totally different from regular rings and that file fit were regular rings that have a .005" OS on the 1st & 2nd rings???
Re: Total Seal Piston rings [Re: RapidRobert] #519790
11/09/09 04:59 PM
11/09/09 04:59 PM
Vitoria, Spain
Coke Offline OP
Coke  Offline OP
Vitoria, Spain
The block is 0.30 over and due the cylinders are ok,the machinist said that it only needs a honing job before to install new rings .
Then will i go better with the file fit rings ?
Thanks for your invaluable help
Re: Total Seal Piston rings [Re: Coke] #519791
11/09/09 05:14 PM
11/09/09 05:14 PM
Mooresville, NC
I
Intense RT Dan Offline
I
Mooresville, NC
Always go the file fit route. You're already there. As far as the gapless Total Seal rings, I was taught that "there may be something to it" but dyno testing is inconclusive as to benefits. If you go gapless, only use a gapless top ring. If gasses get past top rings, you don't want them to build up between second and top rings. This will unseat the top rings. Today's typical practice is to run about .010 extra gap on the second rings, compared to top rings, to keep this from happening. I'd also suggest a 16lb oil ring. With a 44* crosshatch angle and an Roughness Average of 16, I have no oil consumption problems on my 408. My second rings are Napier rings too which probably helps. Perfect Circle makes a nice conventional set, should be about $100, that is file fit and has a nice napier second ring, and, I believe, a lower tension oil ring. Most power and friction reduction will be found in the lower tension oil ring expanders.
BTW, the .035 rings are good for .030 to .035 overbore. An old trick was to use, for example, 4" bore oil ring expanders on a 4.030 setup. Everything else ring-wise, of course, was for a 4.030 bore. Only use the expanders.
Re: Total Seal Piston rings [Re: Coke] #519792
11/09/09 05:19 PM
11/09/09 05:19 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
You'd better go and read what it says on 440Source website again ... the only .035 over rings listed are for 400 ci - NOT 440.
Besides, a .030 ring that is "file fit" will definately need to be filed to fit in that bore - that's why they're called "file fit" !!!
If you look at the p/n for the 400 .035 over ring you will notice it is the same as the 440 .055 set.
Re: Total Seal Piston rings [Re: Stanton] #519793
11/09/09 05:25 PM
11/09/09 05:25 PM
Mooresville, NC
I
I
Mooresville, NC
Just to be sure, it's always better to just call Total Seal for the part number. I took it that he was using the Total Seal lookup on their site.
Re: Total Seal Piston rings [Re: RapidRobert] #519794
11/09/09 05:27 PM
11/09/09 05:27 PM
the ring end gaps overlap.
Re: Total Seal Piston rings [Re: express] #519795
11/09/09 05:37 PM
11/09/09 05:37 PM
This is what confused me as I thought Express was talking about the same type of ring here in both sentences
Re: Total Seal Piston rings [Re: Stanton] #519796
11/09/09 06:42 PM
11/09/09 06:42 PM
Vitoria, Spain
Coke Offline OP
Coke  Offline OP
Vitoria, Spain
They offer the part CR6490-35 for the 440 0.30 over.
If you go to the Jeg´s page and search that reference,it appears like 0.35 rings.
http://www.jegs.com/i/Total+Seal/901/CR6490-35/10002/-1
I suppouse this is why the part number ends like "-35"
The CR6490-35 are 110.490mm bore while the CR6490-30 are 110.617mm
http://www.summitracing.com/parts/TSR-CR6490-30/
http://www.summitracing.com/parts/TSR-CR6490-35/
Wich of both will be more adequate?
That is the question
Regards
Re: Total Seal Piston rings [Re: Coke] #519797
11/09/09 06:54 PM
11/09/09 06:54 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I wouldn't go making any assumptions about a -35 at the end of a part number meaning its .035 over in a 440. The same p/n is only .010 over in a 400! That -35 is likely JUST a part number variant.
The other thing to take note of is the "CR" part number. According to Total Seal, these are "conventional rings" ... meaning they're not "gapless" - hence the need to file fit.
Re: Total Seal Piston rings [Re: Coke] #519798
11/09/09 07:04 PM
11/09/09 07:04 PM
Re: Total Seal Piston rings #519799
11/11/09 11:57 PM
11/11/09 11:57 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
The rings that 440Source is selling are NOT gapless rings, they are all standard rings. Look up any one of the "cr" part numbers on Total Seal's website and it clearly states "Conventional Ring" or "Conventional Classic Race".
It just so happens I got a set from them with my stroker kit last week. Hadn't looked at them yet so thought I'd better check them. Sure enough ... just plain ol' rings.
Re: Total Seal Piston rings [Re: Stanton] #519800
11/14/09 06:03 PM
11/14/09 06:03 PM
Vitoria, Spain
Coke Offline OP
Coke  Offline OP
Vitoria, Spain
I finally have ordered a CR set from 440 source too.
I not going to build nothing for the track,so i suppouse that they will be enough for a street car.
Thanks again
Re: Total Seal Piston rings [Re: Coke] #519801
12/22/09 11:46 AM
12/22/09 11:46 AM
Vitoria, Spain
Coke Offline OP
Coke  Offline OP
Vitoria, Spain
Hello again,
I ordered the total seal rings and took them to the machinist,but i had a small trouble,they are 1.5 mm(1/16" )thick and my pistons need 2mm so i suppouse that they will need 5/64" thick rings ¿?
I will have to order another set,so i considering to order the Total Circle one,like suggested our mate Intense RT Dan
So pay attention on your pistons grooves if you are going to order new rings.
Re: Total Seal Piston rings [Re: Coke] #519802
12/22/09 12:10 PM
12/22/09 12:10 PM
Mooresville, NC
I
I
Mooresville, NC
Hello again,
There's a difference of about .009 to .010 converting 2mm to 5/64. Ask Total seal what the actual width of the groove should be so you are sure. I can't recall proper ring to groove clearance.
I do think it's likely 5/64...which is huge considering nowadays 1/16 is quite thick and heavy.Original Equipment manufacturers are hovering around 1mm. At the least, do yourself a favor, friend, and offset some of this with a total seal ring set with 16LB oil ring set. You'll still have good oil control and reduce friction a good deal. 50% of friction in an engine is the ring set. 50% of THAT number...is from the oil ring set/the expander supplied.
Re: Total Seal Piston rings [Re: Intense RT Dan] #519803
12/22/09 12:46 PM
12/22/09 12:46 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
Total Seal is a brand. Just like Childs and Albert is a brand. Gapless is a design that several manufacturers offer and they can, when the bore is prepped properly, make a difference. Gapless rings still need to be gapped properly. "Gapless" means little way for pressure to escape past. Not a closed circle.
Re: Total Seal Piston rings [Re: moper] #519804
12/22/09 08:16 PM
12/22/09 08:16 PM
Mooresville, NC
I
I
Mooresville, NC
I know I saw a post of your after moper. I read it, went to hit reply, and now it's gone, [Edited by Moparts - Family Friendly Site - Keep it clean]?
Anyway, you've got it. 5/64's with the ring width you got from the spec manual.
Sounds good to me!
