Re: Total Seal Piston rings
[Re: Coke]
#519786
11/08/09 07:29 PM
11/08/09 07:29 PM
Posts: 9,336 South-Central (Sebring), FL
Commando1
the Part# offered by 440 source for the 0.30 over engines (CR 6490-35) seems to be 0.35 over so...
This ring set is for blocks bored .030 and then you file fit them.
[Re: Commando1]
#519787
11/08/09 09:28 PM
11/08/09 09:28 PM
RapidRobert
I have not used them (yet) but it sounds like a good concept. My chebby dyno man says that they do not make any more power than regular (non total seal) ones on the dyno. The regular (non total seal) file fit (.005" OS) rings decrease the gap .0157 (C=Pi x dia). I go with .004 per inch of bore on top rings and .003" per inch of bore on 2nd rings and KB pistons require .006" (or more depending on the app) top ring gap per inch of bore so the more $$$ file fit rings are not needed & if the 2nd ring falls close to .003 per inch of bore using a non .005 OS set you're good.
[Re: express]
#519789
11/08/09 11:43 PM
11/08/09 11:43 PM
RapidRobert
I'm confused. I thought the total seal rings were totally different from regular rings and that file fit were regular rings that have a .005" OS on the 1st & 2nd rings???
[Re: Coke]
#519791
11/09/09 05:14 PM
11/09/09 05:14 PM
Posts: 172 Mooresville, NC
Intense RT Dan
Mooresville, NC
Always go the file fit route. You're already there. As far as the gapless Total Seal rings, I was taught that "there may be something to it" but dyno testing is inconclusive as to benefits. If you go gapless, only use a gapless top ring. If gasses get past top rings, you don't want them to build up between second and top rings. This will unseat the top rings. Today's typical practice is to run about .010 extra gap on the second rings, compared to top rings, to keep this from happening. I'd also suggest a 16lb oil ring. With a 44* crosshatch angle and an Roughness Average of 16, I have no oil consumption problems on my 408. My second rings are Napier rings too which probably helps. Perfect Circle makes a nice conventional set, should be about $100, that is file fit and has a nice napier second ring, and, I believe, a lower tension oil ring. Most power and friction reduction will be found in the lower tension oil ring expanders.
BTW, the .035 rings are good for .030 to .035 overbore. An old trick was to use, for example, 4" bore oil ring expanders on a 4.030 setup. Everything else ring-wise, of course, was for a 4.030 bore. Only use the expanders.
[Re: RapidRobert]
#519794
11/09/09 05:27 PM
11/09/09 05:27 PM
the ring end gaps overlap.
[Re: Coke]
#519797
11/09/09 06:54 PM
11/09/09 06:54 PM
Posts: 8,889 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
If you go to the Jeg´s page and search that reference,it appears like 0.35 rings.
I wouldn't go making any assumptions about a -35 at the end of a part number meaning its .035 over in a 440. The same p/n is only .010 over in a 400! That -35 is likely JUST a part number variant.
The other thing to take note of is the "CR" part number. According to Total Seal, these are "conventional rings" ... meaning they're not "gapless" - hence the need to file fit.
[Re: Coke]
#519798
11/09/09 07:04 PM
11/09/09 07:04 PM
[Re: Coke]
#519801
12/22/09 11:46 AM
12/22/09 11:46 AM
Posts: 340 Vitoria, Spain
Coke
Vitoria, Spain
Hello again,
I ordered the total seal rings and took them to the machinist,but i had a small trouble,they are 1.5 mm(1/16" )thick and my pistons need 2mm so i suppouse that they will need 5/64" thick rings ¿?
I will have to order another set,so i considering to order the Total Circle one,like suggested our mate Intense RT Dan
So pay attention on your pistons grooves if you are going to order new rings.
[Re: Coke]
#519802
12/22/09 12:10 PM
12/22/09 12:10 PM
Intense RT Dan
Mooresville, NC
Hello again,
There's a difference of about .009 to .010 converting 2mm to 5/64. Ask Total seal what the actual width of the groove should be so you are sure. I can't recall proper ring to groove clearance.
I do think it's likely 5/64...which is huge considering nowadays 1/16 is quite thick and heavy.Original Equipment manufacturers are hovering around 1mm. At the least, do yourself a favor, friend, and offset some of this with a total seal ring set with 16LB oil ring set. You'll still have good oil control and reduce friction a good deal. 50% of friction in an engine is the ring set. 50% of THAT number...is from the oil ring set/the expander supplied.
[Re: Intense RT Dan]
#519803
12/22/09 12:46 PM
12/22/09 12:46 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
Total Seal is a brand. Just like Childs and Albert is a brand. Gapless is a design that several manufacturers offer and they can, when the bore is prepped properly, make a difference. Gapless rings still need to be gapped properly. "Gapless" means little way for pressure to escape past. Not a closed circle.
