Milodon Gear Drive Question #519685
11/08/09 06:05 PM
11/08/09 06:05 PM
U.S.
moparniac Offline OP
U.S.
This is my first milodon setup and I dont like the pointer setup on... depending where you head is seems you will be looking at a different degree when setting timing.... Is there anything better out there ??? thx
Mopar Performance
Re: Milodon Gear Drive Question [Re: moparniac] #519686
11/08/09 07:12 PM
11/08/09 07:12 PM
U.S.
U.S.
Mopar Performance
Re: Milodon Gear Drive Question [Re: moparniac] #519687
11/08/09 07:19 PM
11/08/09 07:19 PM
Mopar Lane,Mississippi
67HEMI Offline
67HEMI  Offline
Jesel belt drive.
'33 Plymouth 5 Window Coupe Blown Aluminum HEMI w/bolt ons (under construction) '69 Chrysler 300 Convertible 375 HP 440 '71 Plymouth Duster 360 W/EFI (Wife's Ride) '12 Ram MegaCab Dually 6.7 Cummins
Re: Milodon Gear Drive Question [Re: 67HEMI] #519688
11/08/09 07:26 PM
11/08/09 07:26 PM
U.S.
U.S.
I was if there was something else better to use other than that little pointer that screws in...
Mopar Performance
Re: Milodon Gear Drive Question [Re: moparniac] #519689
11/08/09 07:44 PM
11/08/09 07:44 PM
you can make a better marker with sheet metal, if you have the knack and talent I don't I have to pay someone to make little brackets like that so the other guys don't laugh at my fabricating skills You might be able to use one of the bolt on timing brackets that come with the Mopar chrome timing covers also I think I've done that on a Jesel belt drive or a gear drive like the Milidon, Donovans and KB in the past
Re: Milodon Gear Drive Question [Re: Cab_Burge] #519690
11/08/09 08:13 PM
11/08/09 08:13 PM
U.S.
U.S.
wonder if andyf has anything
Mopar Performance
Re: Milodon Gear Drive Question [Re: moparniac] #519691
11/09/09 12:53 PM
11/09/09 12:53 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I made a longer one ( 1/4 long bolt)and then bent it 90 then 90 sharpened it so it was right by the balancer the did the old piston stop thing to dial it in exact. also got one now that is jst crudly fabed up pointer from one of the top gear cover bolts!
you can just barely see it in this picture
Re: Milodon Gear Drive Question [Re: Dodgem] #519692
11/09/09 09:30 PM
11/09/09 09:30 PM
San Diego, CA
brktracr Offline
super street
brktracr  Offline
super street
San Diego, CA
I have a Milodon so I put on a crank trigger. Works great.
1.298 60 ft 6.001 1/8 mile 114 mph 9.52 1/4 mile 140.87 mph @ 3110 lbs
Re: Milodon Gear Drive Question [Re: brktracr] #519693
11/10/09 08:49 AM
11/10/09 08:49 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Mancini's has this looks like you could make this work?
http://chucker54.stores.yahoo.net/adbbitipo.html
Source has this looks like it could be adapted
http://store.440source.com/Billet-Aluminum-Timing-Pointer/productinfo/200-1073/
Re: Milodon Gear Drive Question [Re: moparniac] #519694
11/10/09 09:38 AM
11/10/09 09:38 AM
67HEMI Offline
67HEMI  Offline
If he does Mancini sells it. Have you bought his book yet? It is a good read and has some cool parts in it as well.
