Late model plastic M/C caps leaking #519645
11/08/09 05:07 PM
11/08/09 05:07 PM
Tampa Florida
dc426 Offline OP
gotta keep'm separated
dc426  Offline OP
Tampa Florida
I changed Master cylinders a while back when I had brake issues. They are/were both later model plastic reservoir bodies with the black plastic caps. Now for some reason I can't get the caps to stop leaking. I've reduced the amount of brake fluid in there. I've swapped out the rubber cap inserts, tried front to back and back to front. they still leak. Anyone else have this problem and a solution???
DC.
Re: Late model plastic M/C caps leaking [Re: dc426] #519646
11/08/09 05:16 PM
11/08/09 05:16 PM
USA
Ron Silva Offline
Ron Silva  Offline
USA
There is like a channel in the caps for venting purposes I think. I would always make sure that after the caps are screwed on the this is toards the front of the car. It's a raised area on the cap.
SRT DEMON ONE SEAT
Re: Late model plastic M/C caps leaking [Re: Ron Silva] #519647
11/08/09 05:22 PM
11/08/09 05:22 PM
Tampa Florida
dc426 Offline OP
dc426  Offline OP
Tampa Florida
Ok, so the vent goes in the front? I currently have it on the back and facing back. Only one cap with the vent in it.
DC
Re: Late model plastic M/C caps leaking [Re: dc426] #519648
11/08/09 08:09 PM
11/08/09 08:09 PM
TN
65racer Offline
2009 IHRA World Champion
65racer  Offline
TN
Had the same problem with mine, so I just used an old antifreeze plastic jug, cut some circles out of it to just fit in the caps, under the rubber grommets, and have not had a leak since, try this I bet it will stop the leakage problem.
Re: Late model plastic M/C caps leaking [Re: 65racer] #519649
11/08/09 08:22 PM
11/08/09 08:22 PM
Tampa Florida
dc426 Offline OP
dc426  Offline OP
Tampa Florida
good idea
Re: Late model plastic M/C caps leaking [Re: dc426] #519650
11/08/09 08:31 PM
11/08/09 08:31 PM
Boise
Moparteacher Offline
Boise
The vent in the cap allows atmospheric pressure to the top side of the rubber grommet. As the brakes wear and the fluid level drops the grommet also drops and displaces the area previously occupied by fluid. At no time is the fluid exposed to the atmosphere, for brake fluid is hydroscopic. It absorbs moisture from the atmosphere like a sponge.
So...if it's leaking it's not because of overfilling. It's probably because the fluid is contaminated with moisture resulting in fluid expansion when hot,pushing past the rubber grommet.
Flush all the fluid out and refill with new fluid from a sealed container.
BTW. DOT 5 fluid tends to form microscpoic bubbles when pumped quickly, these can be difficult to eliminate through bleeding. Use DOT 3.
Re: Late model plastic M/C caps leaking [Re: Moparteacher] #519651
11/08/09 10:18 PM
11/08/09 10:18 PM
Tampa Florida
dc426 Offline OP
dc426  Offline OP
Tampa Florida
I can tell ya it's not over filled because I removed a lot just to see if it would stop leaking. As far a contaminated, it doubt it because the whole system is new and has done it from the beginning.
Re: Late model plastic M/C caps leaking [Re: Ron Silva] #519652
11/09/09 06:23 PM
11/09/09 06:23 PM
USA
Ron Silva Offline
Ron Silva  Offline
USA
I gave you bad info. Sorry. For some reason I thought there was a very small hole in the rubber diaphram under the cap. I was wrong. The diaphram baloons to allow for the receeding level of brake fluid as the brakes wear and is air tight.
SRT DEMON ONE SEAT
Re: Late model plastic M/C caps leaking [Re: Ron Silva] #519653
11/09/09 06:47 PM
11/09/09 06:47 PM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
Mine on my demon does the same thing, Ill try making the vent to the front also, THanks guys...
Kasey
Re: Late model plastic M/C caps leaking [Re: Moparnut426] #519654
11/09/09 07:48 PM
11/09/09 07:48 PM
Detroit,MI
BADDART Offline
BADDART  Offline
Detroit,MI
I made spacers for under the rubber seals from the lid of a cool whip tub.Worked great,no more leak after every drive. Chris
Re: Late model plastic M/C caps leaking [Re: BADDART] #519655
11/09/09 08:05 PM
11/09/09 08:05 PM
Castle Rock, CO
W
wegner426 Offline
wegner426  Offline
W
Castle Rock, CO
Having the same problem with mine.....I will "see what I can see" with the vents and home made spacers tonight.
Re: Late model plastic M/C caps leaking [Re: wegner426] #519656
11/09/09 08:19 PM
11/09/09 08:19 PM
Clinton Township, Michigan
Dartin Offline
Dartin  Offline
Good info here! I've been having this same broblem, too. Real annoying!
