Re: Transmission "issues"
[Re: dartman366]
#518596
11/07/09 09:06 PM
11/07/09 09:06 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
I have 2 solid mounts and a poly trans mount and haven't broken a tail shaft like that.
[Re: WILD BILL]
#518597
11/07/09 09:22 PM
11/07/09 09:22 PM
dartman366
Mt. Vernon, Ohio
not saying it won't work, I know other's that have the same setup, but they also don't have chassis/body flex, also know of a couple that had to go to a rubber mount to get the extention housing's to live, and these are not just torqueflites. one fellow had a turbo 350 and another had a powerslide in a chevelle, if he didn't break the tail housing then it would be a case, they both went to rubber mount's and presto.
[Re: Big Wedge]
#518600
11/08/09 12:22 PM
11/08/09 12:22 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
The K memeber might have been flexing enough to crack it.. The poly mount probably isnt allowing much trans movement or twisting.. So the trans is rock solid, and the front engine block/K member is flexing..something has to give which is the weakest link..The cast aluminum tailshaft housing. Get the engine mounts off the think K member and get a motor plate..or atleast add some torque straps on each side off the frame rails to hold that engine still.
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
