Re: 904 question
[Re: dart70]
#518417
11/07/09 07:37 PM
11/07/09 07:37 PM
dartman366
Mt. Vernon, Ohio
If I remember correctly, I don't believe there is any oil going to the govenor after the RMVB is installed, so you could just gut it, I made a spacer to fill in for the govenor housing on mine, any local machine shop could make one easy enough, all it does is keep the parking pawl in location.
Re: 904 question
[Re: dart70]
#518420
11/08/09 02:52 PM
11/08/09 02:52 PM
dartman366
Mt. Vernon, Ohio
If that is the case, then are the sealing rings from the governor housing (parking pawl) to output shaft support necessary anymore?
probably not but i am not sure if they seal to a passage in the rear support, I left mine in as it won't hurt to have them there even if there is no oil at that point, but then again the inner ring may seal the center dia which if I remember correct is fed oil from the system and may bleed past.
