Window rollers for Challenger ? #518143
11/07/09 12:22 PM
11/07/09 12:22 PM
Garden Grove, CA
OzHemi Offline OP
Penguin-hating Ginger
OzHemi  Offline OP
Garden Grove, CA
Where would be the best source for new window rollers for a '72 Challenger? (window is flopping all around inside the door at the moment in Oz )
Re: Window rollers for Challenger ? [Re: OzHemi] #518144
11/07/09 01:27 PM
11/07/09 01:27 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
These guys might have it.
http://www.hooverautoparts.com/
Re: Window rollers for Challenger ? [Re: Neil] #518145
11/07/09 08:57 PM
11/07/09 08:57 PM
Garden Grove, CA
OzHemi Offline OP
OzHemi  Offline OP
Garden Grove, CA
Lemme take a peek
Re: Window rollers for Challenger ? [Re: OzHemi] #518146
11/08/09 08:47 PM
11/08/09 08:47 PM
MN
astrobuf Offline
astrobuf  Offline
MN
Well, it depends a bit upon just what's broken in the door. I've just completed a full resto of my 71 Chally door regulators. It's a good bit of work with lots of little picky stuff to do.
Order your parts from Tom Race at RT Specialties. The regulator sliders seem to be only available from him. Note, the studs the sliders come with are much smaller than original and so to install, you'll need to carefully upset the stud with a center-punch to ensure it swadges into the regulator arms.
Clean and lube up the big sliders and the vertical channel. I used Sil-Glide grease liberally. Tom will have new sliders, gaskets, stops and other bits and pieces too.
Astrobuf
So, are you really a Rocket Scientist?
Re: Window rollers for Challenger ? [Re: astrobuf] #518147
11/08/09 08:55 PM
11/08/09 08:55 PM
N.E. Ohio
mike69rr Offline
mike69rr  Offline
N.E. Ohio
tom at R/T sells a kit with the rollers and other things for a basic rebuild. might want to check into that if needed.
Re: Window rollers for Challenger ? [Re: mike69rr] #518148
11/09/09 09:04 PM
11/09/09 09:04 PM
Garden Grove, CA
OzHemi Offline OP
OzHemi  Offline OP
Garden Grove, CA
Thanks guys....I will check there too. Just need them kind of soon is all (buddy needs them to take back to Oz) and heard in the past about Tom being kinda slow perhaps
But I will check...and thanks for the info again !
Re: Window rollers for Challenger ? [Re: OzHemi] #518149
11/09/09 09:07 PM
11/09/09 09:07 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Tom at R/T is the manufacturer should you happen to not get hold of Tom .
Try Jamie at Megaparts , he carries them as well
Re: Window rollers for Challenger ? [Re: gtx6970] #518150
11/10/09 12:31 AM
11/10/09 12:31 AM
Garden Grove, CA
OzHemi Offline OP
OzHemi  Offline OP
Garden Grove, CA
Thanks Bill
Do you deal in them too?
Re: Window rollers for Challenger ? [Re: OzHemi] #518151
11/10/09 07:39 AM
11/10/09 07:39 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Not at this time. maybe after the 1st of the year I'll give them more consideration
Re: Window rollers for Challenger ? [Re: gtx6970] #518152
11/10/09 12:03 PM
11/10/09 12:03 PM
Garden Grove, CA
OzHemi Offline OP
OzHemi  Offline OP
Garden Grove, CA
Ok...was going to get them from you, if you did.
I'll order them tonight it looks like from somewhere or other...better get them on the way so my buddy can take them back to Oz in his luggage
Re: Window rollers for Challenger ? [Re: gtx6970] #518153
11/15/09 12:38 PM
11/15/09 12:38 PM
Garden Grove, CA
OzHemi Offline OP
OzHemi  Offline OP
Garden Grove, CA
I ordered them there, and got them super fast, definate from me!
