Idle stop selenoid?? #517999
11/07/09 11:00 AM
11/07/09 11:00 AM
Poplar Bluff, Mo. 63901
2
268RTs4ME Offline OP
Working on 74 440 auto, my thermoquad has an idle stop selenoid mounted on the right side, which is my understanding is how you set the idle, I am trying to find out where the plug end off of it hooks up at, I only have one wire out of my harness there, which should go to my A/C Unit, which should only get 12 volt when I turn A/C on,.should a constant 12 V off the ignition be going to the selenoid????
Re: Idle stop selenoid?? [Re: 268RTs4ME] #518000
11/07/09 12:41 PM
11/07/09 12:41 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
