help 440 timing #517852
11/06/09 10:26 PM
11/06/09 10:26 PM
Chicagoland
stacks79 Offline OP
stacks79  Offline OP
Chicagoland
hello, first 440 build. how do you see the timing marks on the timing cover in the vehicle?? that plate is so small and half hidden i cant see anything in a straight line of view. i have to use a mirror just to see the thing, let alone get a timing light to it. i noticed there is a hole in it, i assume tdc? trying to wire up all the plug wires tonight so i can fire it up tomorrow. any help would be appreciated. thanks, john
Re: help 440 timing [Re: stacks79] #517853
11/06/09 10:38 PM
11/06/09 10:38 PM
Kirkland, Washington
Pacnorthcuda Offline
The hole is at 0 degrees, take a good look at it and determine the graduations before you read it while its running. You're much better off putting timing tape on the damper.
Re: help 440 timing [Re: Pacnorthcuda] #517854
11/06/09 10:57 PM
11/06/09 10:57 PM
Chicagoland
stacks79 Offline OP
stacks79  Offline OP
Chicagoland
thanks, i figured the hole was tdc, but wanted to confirm, this is what i am up against, after a little web surfing, i have seen a few timing tabs, mine looks nothing like some of the others, ie, easier to read. How do you get a timing light to see down here, first pic you can just see the damper slit, second you can just see the tab, and thoat is only because i have my hand down in the fan at the level of the tab, no way i can get down there with the engine runnin!! John
Re: help 440 timing [Re: stacks79] #517855
11/06/09 11:02 PM
11/06/09 11:02 PM
That doesn't look so bad, other than the lines on tab are hard to distinguish. Clean up the tab with brush or sand paper. Internet search to get a better pic that will show what the lines are (I think each line is 5 degrees)
Re: help 440 timing [Re: Pacnorthcuda] #517856
11/06/09 11:06 PM
11/06/09 11:06 PM
Chicagoland
stacks79 Offline OP
stacks79  Offline OP
Chicagoland
thanks for the reply, but what my question is, is how am i suppost to view it with the engine running? i do not have a straight line of sight to the tab or hole, i only got that pic cause i stuck my hand down in there. my timing light is adjustable at the gun, so i can set my timing there, but i just need to see the hole, i did not know if it was something else missing, some other tool, etc... thanks. John
Re: help 440 timing [Re: Pacnorthcuda] #517857
11/06/09 11:19 PM
11/06/09 11:19 PM
clean the tab & put 4 dabs of white paint on it on the front edge (the line at the hole (TDC) and the 3 lines CCW from it 5, 10 & 15 btdc and clean & paint the groove on the dampener & you'll be easily able to see it w your light.
Re: help 440 timing [Re: RapidRobert] #517858
11/06/09 11:25 PM
11/06/09 11:25 PM
Canada
CrAzYMoPaRGuY Offline
Canada
My Jensen Interceptor has the same side tab and waterpump as you, I cleaned my balancer, painted it black, dabbed white paint in the timing notch, marked the balancer for 34 and 36 degrees BTDC and cleaned the tab up.
My hood opens backwards so I have reduced view of the front of the engine but I can still see the marks pretty easily.
If the marks aren't clearly defined it's tough to see while running....
CrAzYMoPaRGuY
Re: help 440 timing [Re: CrAzYMoPaRGuY] #517859
11/06/09 11:38 PM
11/06/09 11:38 PM
You could make a new mark 2&1/4" CW from the groove on the dampener for 35.5 BTDC and it's always a good idea to check exact TDC with the piston stop.
Re: help 440 timing [Re: RapidRobert] #517860
11/07/09 09:21 AM
11/07/09 09:21 AM
SW Fla.
CYACOP Online content
CYACOP  Online Content
SW Fla.
Is that 2 and a 1/4" around the radius of the balancer or straight across? I want to mark mine up before I install it.
Re: help 440 timing [Re: CYACOP] #517861
11/07/09 10:13 AM
11/07/09 10:13 AM
Around. A flexible sewing tape or something similar works good. .0632683" = 1 degree so 36 degrees would be 2.2776" (2.278") and 38 degrees is 2.404" & you could cut 2 pieces of stiff wire & get em to that exact length with your 2-3" mike. 35 & 1/2 degrees just happens to be 2&1/4" which is easy to get w a sewing tape. I would check exact TDC first though. Cant assume nothing & thoroughness will enable you to top the guy in the next lane who does not have our (Mopar) dedication.
Re: help 440 timing [Re: RapidRobert] #517862
11/07/09 10:20 AM
11/07/09 10:20 AM
SW Fla.
SW Fla.
Re: help 440 timing [Re: stacks79] #517863
11/23/11 04:22 PM
11/23/11 04:22 PM
Mississippi
lahatte Offline
lahatte  Offline
Mississippi
It boggles the mind, why they didn't put the timing tab on the battery side, where it's easy to see, and where you make all the connections.
Re: help 440 timing [Re: lahatte] #517864
11/23/11 04:46 PM
11/23/11 04:46 PM
Scranton, PA
Montclaire Offline
Montclaire  Offline
Scranton, PA
You could just do it by ear, I never used a timing light. If you've spent enough time around the car you know when you're good and when you're not.
Re: help 440 timing [Re: Montclaire] #517865
11/23/11 05:52 PM
11/23/11 05:52 PM
scratchnfotraction Offline
my 440 does not have a belt runing down to the crank behind the wp pully,i think thats why it so hard to see with the light.
remove the belt till you get it set if that will open up the veiw any.
I use a vac gauge to get highest vac reading then look and see where its at,then adjust acordingly from there.
mine set at the end edge of the tab and pulls 18" of vac at idle
I sand balsted mine then marked with paint,then marked the damper with yellow.
hardest thing for me was to remember when i steped up to a BB is the BB dist turns CCW and a SB turns CW and the tab has the ATDC and BTDC on opisite side of the scales
glad to see you back,been a while
Re: help 440 timing [Re: scratchnfotraction] #517866
11/23/11 06:35 PM
11/23/11 06:35 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
clean that thing up..... it'll be much easier to see. I've painted white stripes on either side of the mark to make it easier to see.
Coming soon!!!!
Re: help 440 timing [Re: Montclaire] #517867
11/23/11 07:06 PM
11/23/11 07:06 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Re: help 440 timing [Re: Mr.Yuck] #517868
11/23/11 07:06 PM
11/23/11 07:06 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Hillbilly timing tape.
Each mark is 15* apart.
Bottom line is TDC, The others are 15 and 30* BTDC.
Re: help 440 timing [Re: JohnRR] #517869
11/23/11 07:13 PM
11/23/11 07:13 PM
I have fixed more chebbys with a timeing light and vac gauge because they were set by ear
few mopars as well,not knocking it,i do it myself and then check it with a light to see how close it is.
the light does not lie and it is allways too far advanced have been my results
Re: help 440 timing [Re: scratchnfotraction] #517870
11/23/11 07:17 PM
11/23/11 07:17 PM
TX
Gunner80 Offline
Gunner80  Offline
TX
You have the later model water pump housing which is a right hand lower hose the earlier models had a left hand lower hose water pump housing and much easier to see
Re: help 440 timing [Re: Montclaire] #517871
11/23/11 09:13 PM
11/23/11 09:13 PM
indiana
mcmopars Offline
mcmopars  Offline
indiana
really? i always use a timing light on performance engines to get the most out of what i have.now a 200 hp putt around i quess ear would be ok
