Re: New MOPAR 5 speed from McLeod!!!!!!!
[Re: LAR_414]
#517302
11/06/09 10:35 AM
11/06/09 10:35 AM
Posts: 1,262 Netherlands
72Challenger
Netherlands
Looks good for the currently more and more big ci / mighty hp streetcars being build. Of course the big Q will be what it will survive on the strip I guess. It's just not me who will figure it out as I just ordered a GForce GF4A trans for the racer. As said, at least it looks tuff!
[Re: StrokerAspen]
#517309
11/06/09 03:31 PM
11/06/09 03:31 PM
Posts: 7,498 Minnesota
Hemi_Joel
Minnesota
I saw it at SEMA, Red from mcleod said they were thrashing to get it done in time for the show. The cluster gear is multi-peice, that allowed them to put a bearing in the middle of it that mounts in a bulkhead thru the middle of the case. That's where the strength comes from. THe overdrive is mounted in the tailshaft housing. It is all syncronized, so I don't know how well it will shift in drag racing applications. I suppose it can be slick shifted just like any 833 trans. I think he mentioned that 2300 price to me also. He also said they came in second place for best new product at SEMA.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: JohnRR]
#517313
11/06/09 06:40 PM
11/06/09 06:40 PM
Posts: 10,558 Rittman Ohio
fourgearsavoy
Rittman Ohio
That shifter set-up looks like it could be the Achilles heel for street use and strips with dust covered pits.Other than that I like the look of it and it looks like you wouldn't need much fabrication to install it in any car. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: Jeremiah]
#517315
11/06/09 08:19 PM
11/06/09 08:19 PM
Posts: 9,892 Weddington, N.C.
Streetwize
Weddington, N.C.
Wonder what the gear ratios are??? the Tremec 1 is too deep and the 1-2 is a little wide, I could go for a close to even spread 4 speed with a .8 od. Something like: 2.56 1.92 1.28 1 .8
