Best way to clean piston grooves? #517137
11/05/09 10:23 PM
11/05/09 10:23 PM
Canuckville
68Cbarge Offline OP
68Cbarge  Offline OP
Canuckville
I am rebuilding a 68 383 that sat since 1973.It has 62,000 miles on it.
I got it running but time was not kind to the internals.
Everything is apart and now I am cleaning things up.
Block,crank,and heads are back from the machine shop.
The top of the pistons cleaned up well.
I removed the rings and the two upper grooves are full of hard carbon.
How do I clean it out without damaging the pistons?
I tried combustion cleaner and a broken ring but this crap is stubborn.
Should I just send them to the machine shop for hot-tanking?
I am doing as much as possible to keep costs down.
Any tips/advice is greatly appreciated.
'68 Newport Custom Barge on a Budget!! BOAB
1973 Satellite WAGON! 318- 3 on the tree!!
2008 Chrysler 300c HEMI!
Re: Best way to clean piston grooves? [Re: 68Cbarge] #517138
11/05/09 10:27 PM
11/05/09 10:27 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Can't hot tank a aluminum piston. Used to soak them in carb cleaner. Now they make spray gun cleaner in 1 gallon cans that works great and the same as the old carb cleaner. Called spray gun cleaner at the auto paint stores.
Re: Best way to clean piston grooves? [Re: 68Cbarge] #517139
11/05/09 10:28 PM
11/05/09 10:28 PM
soak them in your carb soup. EDIT then break a old ring & on your bench grinder grind the end on the inside narrower to a slight hook shape & square up the broken end & carefully scrape as to not remove any piston material.
Re: Best way to clean piston grooves? [Re: RapidRobert] #517140
11/05/09 10:34 PM
11/05/09 10:34 PM
Canuckville
68Cbarge Offline OP
68Cbarge  Offline OP
Canuckville
Thanks,guys.
I will try to see if it is available up here.
If not I can use GM Combustion Cleens or a Kleen-Flo equivalent
Re: Best way to clean piston grooves? [Re: 68Cbarge] #517141
11/05/09 10:59 PM
11/05/09 10:59 PM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
use an old ring broken off... careful they are sharp! then carb clean em dan
Re: Best way to clean piston grooves? [Re: ph23vo] #517142
11/05/09 11:11 PM
11/05/09 11:11 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
If I'm not mistaken, there is a special tool that you spin around the piston a couple times and clean as new. Been over 25 years since I've used one, but they worked great. Maybe you can rent one?
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: Best way to clean piston grooves? [Re: GO_Fish] #517143
11/05/09 11:23 PM
11/05/09 11:23 PM
USA
JoesMopar Offline
JoesMopar  Offline
USA
Use an old ring, break it, and ream it around and around until you get all the carbon out.
Then take some parts washer cleaner on an old toothbrush and scrub it real good. This should clean them up good enough without having to hot tank the pistons since your basically just re-ringing them.
Re: Best way to clean piston grooves? [Re: JoesMopar] #517144
11/06/09 02:52 AM
11/06/09 02:52 AM
Rancho Cucamonga, CA
D_C Offline
D_C  Offline
Piston Groove Cleaner.
Carb Dip and Piston Cleaner
Re: Best way to clean piston grooves? [Re: D_C] #517145
11/06/09 02:58 AM
11/06/09 02:58 AM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
IF there is a bunch of carbon in there .. there probably is a lot of slop in the ring groove ... not good.
BTW ...what is that spec?
Re: Best way to clean piston grooves? [Re: dOc !] #517146
11/06/09 09:29 AM
11/06/09 09:29 AM
scratchnfotraction Offline
I get the 5 gallon pale of carb cleaner from napa
about a 20 min soak and rinse them..no need to scrape,I then rinse in diesel fuel to keep stuff from flash rusting
i clean 4 at a time
very fast and will clean a lot of the stuff on the engine rebuild
wear gloves and have plenty of vetalation for sure..
Re: Best way to clean piston grooves? [Re: 68Cbarge] #517147
11/08/09 10:52 AM
11/08/09 10:52 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
somewhere on the web there is an article about cleaning carbon off of aircraft engine pistons where they tested a new liquid cleaner on three different badly carbonned-up pistons and got excellent results... but I can't find the article right now.
this weblink to OTC brand decarbonizing fluid was in my bookmarks:
http://www.etoolcart.com/browseproducts/Decarbonizing-Fluid-OTC7904A.html
when I tried soaking 1994 Magnum 5.9V8 pistons several years ago the fluid they sold at BMW and VW dealerships named
'LubroMoly Ventril Sauber'
took off the carbon deposits the best,
better than
Chevron Techron, or Chrysler ATF+2, or BG Chemtool
Re: Best way to clean piston grooves? [Re: scratchnfotraction] #517148
11/08/09 11:51 AM
11/08/09 11:51 AM
Cincinnati, Ohio
Cincinnati, Ohio
Do they still sell it?
The stuff I used to use was called Hydro seal or something like that. You had to keep a layer of water floating on top to keep the chemical from evaporating. I was told by the auto parts guys they quit selling it for EPA reasons a long time ago.
A year ago or so I bought a gallon of paint gun cleaner,(big $$ 25.00 or something like that) it seems like the same thing, anything aluminum I put in it get's stripped really well. Worked great for soaking really dirty spray guns and cups. I used it to strip a few small parts too. All my spray guns are spotless now.
I use it in a different container and then strain it as I'm pouring back into the storage can, reusable. It would do one piston at a time.
Re: Best way to clean piston grooves? [Re: Challenger 1] #517149
11/08/09 02:23 PM
11/08/09 02:23 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Take an old ring, break it and have at it. That's all I did and that's what the instructions in my ring kit said to do as well as the instructions in my mopar fsm. Yes it is stubborn. It helps if you break the ring at just the right length so it's semi comfortable to hold and the right length to scrape good. After I get the caked on carbon out of there I clean it down with solvent.
