I am rebuilding a 68 383 that sat since 1973.It has 62,000 miles on it.
I got it running but time was not kind to the internals.
Everything is apart and now I am cleaning things up.
Block,crank,and heads are back from the machine shop.
The top of the pistons cleaned up well.
I removed the rings and the two upper grooves are full of hard carbon.
How do I clean it out without damaging the pistons?
I tried combustion cleaner and a broken ring but this crap is stubborn.
Should I just send them to the machine shop for hot-tanking?
I am doing as much as possible to keep costs down.
Any tips/advice is greatly appreciated.
