7 pin wiper switch/2 speed wiper motor problem...
#517053
11/05/09 07:59 PM
11/05/09 07:59 PM
Posts: 565 IA
landon1
IA
re-wired the car and this is the only item i'm still having a problem with. i have an "extra" terminal on the wiper switch i don't know what it goes to, but i also tried a 6 pin switch i had laying around, wired it how it should be, and got nothing. when the 7 pin switch is hooked up, you can hear a circuit breaker type click from inside the switch. the motor spins and will move the wiper arms while spinning it by hand, but i am not getting power to the switch for some reason...
car is early '71 (aug '70) plymouth satellite - standard dash, 2 speed wipers, electric washer pump if it matters
'71 Satellite Sebring 440
Re: 7 pin wiper switch/2 speed wiper motor problem...
[Re: repad]
#517055
11/05/09 08:50 PM
11/05/09 08:50 PM
Posts: 565 IA
landon1
IA
could be my issue, as i built my own cluster of aluminum - may have to run a ground wire from switch to the dash frame...i'll look into it
is there a way to try and supply power to the motor to make sure there isn't a problem with it?
[Re: convertriple]
#517057
11/05/09 10:38 PM
11/05/09 10:38 PM
Posts: 565 IA
landon1
IA
that's what i was noticing as well, but i wasn't getting power to the motor for some reason (possibly switch needing to be grounded)...i had the power wire connected and would go through the speeds and pushing it in for the washer, using the test light everything seemed fine, but i was getting the "click" coming from the switch like a breaker. the stock harness had a connector with gray wire coming off of the 7th pin, but it didn't go to anything - pretty hacked-up, hence the new harness
[Re: 72roadrunnergtx]
#517059
11/06/09 09:35 AM
11/06/09 09:35 AM
Posts: 6,139 Valencia, EspaƱa
NachoRT74
Valencia, EspaƱa
yes, 72 and later switch carries diff wiper switch prongs disposition and in fact is one solid plug with all wires on it, diff than 71, with wider prongs disposition and using two diff plugs. HOWEVER wires and colors are the same. 72 and laters switch is smaller too.
extra prong is ground reinforcement, what REALLY is not needed once mounted. Cluster attachment provides enough ground
[Re: NachoRT74]
#517060
11/06/09 09:52 PM
11/06/09 09:52 PM
Posts: 565 IA
landon1
IA
will get some pics - wipers worked fine before, but for some reason while i was building my motor, the entire electrical system took a dive...so i replaced the entire chassis harness with a universal unit. running wiper power to the B terminal (pink stock wire)...then running the other wires in stock colors out to motor. the extra terminal threw me off a bit - i will try grounding the switch when i make it back to my car. my stock 71 switch is a lot different from the 6 pin switch i have from a later b-body (73 charger i believe), which i tried using. hopefully the switch being grounded will solve this issue. i don't drive much and normally only in good weather, but don't really want to get stuck and not have them. thanks for the diagrams and instructions on testing the motor doug. i really should invest in a FSM...maybe a birthday present to myself next month
