Re: Moroso Speed calculator, and actual track results?
[Re: BradH]
#516892
11/07/09 07:11 AM
11/07/09 07:11 AM
Posts: 1,608 Rudolph, Ohio
moparguy7074
Rudolph, Ohio
The Moparts online calculator matches up pretty closely to the engine dyno HP I got from PRH's dyno, even though it, just like the Moroso tool, is said to calculate RWHP.
Whats this Moparts calculator of which you speak?
[Re: moparguy7074]
#516893
11/07/09 07:49 AM
11/07/09 07:49 AM
Posts: 8,647 ELYRIA,OH
blownzoom440
ELYRIA,OH
http://www.moparts.org/Tech/tech/index.html 734 rwhp for me 134mph/3900lbs
[Re: JD Dart]
#516896
11/07/09 10:36 PM
11/07/09 10:36 PM
fast68plymouth
So. Burlington, Vt.
1968 Pontiac GTO NHRA F/S (stick car). 400 Pontiac, Q-jet, .420 lift hyd cam, stock intake, stock heads. 3620 race weight.
470hp on the SF-901 engine dyno. 410hp on the Dyno-Jet chassis dyno.
set the record with that combo 10/2005......10.97 and like 122mph.
same motor in a 68 Firebird, same weight, same class.....set the record again last year, 10.79 @ 123.
shows around 500hp on the Moroso calc.
who really thinks that motor combo will make 500 "RWHP" ?
just had a customer try out a new motor in his car last week. 2700lbs, ran 8.53 @ 163......made 766RWHP. i think it shows like 850+ on the Moroso calc.
[Re: fast68plymouth]
#516897
11/07/09 11:15 PM
11/07/09 11:15 PM
i rest my case. i didn't mean to offend anyone on purpose, i'm just trying to prove a point. if anyone feels better about their combo because some slide rule says it makes tons more power than it actually does, well, i guess that's their right. it just makes guys like me feel better (and look better) when our 600 HP combo stomps the supposed slide rule 700 HP combo.
#516898
11/08/09 02:13 AM
11/08/09 02:13 AM
Posts: 49 naperville,illinois
orange71rt
naperville,illinois
I have engine dynoed my motor and chassis dynoed at rear wheels,at the crank it made 832 hp , at the rear wheels it made 652hp.The car weighs 3,600 lbs with me in it.It ran 9.63 at 138.8 mph.I run the car on pump gas 93 octane only and it was dynoed both at the crank and rear wheels with 93 octane.According to moroso speed calculator the hp should be 738 hp.This is almost smack in the middle of both readings ,go figure.I too have been trying to figure out for a long time if the moroso speed calculator is at the crank or rear wheel hp.I guess its another good tuning tool in the quest for faster times and mph.
[Re: orange71rt]
#516899
11/08/09 09:27 AM
11/08/09 09:27 AM
it's just another happy engine dyno by about 100 HP. the other numbers seem to fall in line okay.
[Re: orange71rt]
#516903
11/08/09 10:47 AM
11/08/09 10:47 AM
Posts: 10,016 Frostbitefalls MN (Rocky&Bullw...
gregsdart
832 would seem very close to the true dyno number to me. Not to mention that is purty fast for a 36oo lb car! Just for grins I put those numbers through the 5.825 constant formula, and came up with 797 hp. That would match the dyno numbers pretty close when you figure in the weather conditions for that day I bet. Do you keep weather stats, or have the date and time plus track name and location? There is a web site that keeps all the stats and can give you corrected et and mph. www.dragtimes.com/da-density-altitude-calculator.php
[Re: BSB67]
#516907
01/12/11 09:43 PM
01/12/11 09:43 PM
Posts: 6,295 U.S.
moparniac
U.S.
I've studied and compared some engine dyno, "Power Calculator" and RWHP numbers on a few combinations and have come to this conclusion: All three are different, but correlate well (i.e. engine dyno highest, RWHP lowest, and Speed Calculator in the middle)
The engine dyno is gross corrected flywheel HP.
The Moroso Calculator is actual net flywheel HP. and,
Chassis dyno is corrected RWHP.
If you run your car when the DA is 0, have no accessories running off the engine and same engine dyno exhaust system, The Morroso HP will match closely the engine dyno results (assuming it's not happy).
this makes sense to me
Mopar Performance
[Re: moparniac]
#516908
01/12/11 09:59 PM
01/12/11 09:59 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I have called Moroso on this several times and they say its RWHP every time
I heard from other people its NET!
I've come to the conclusion that its fly wheel HP, I had my car on a chassis dyno and it showed 565 hp at the tire (but I really dont believe a chassis dyno with a loose conv)... by rights the pulls should have had reasonable numbers from 6000 to 8200
