VooDoo cam experience #516743
11/05/09 03:33 PM
11/05/09 03:33 PM
Wis., USA
Bob_Fromm Offline OP
Wis., USA
Polling the Mopar group for feedback in their experience with the VooDoo cams. Mine is not so satisfying.... Built a new 440 over the winter, 10.2 real cc'd compression, 440 Source heads, CH4B intake, 800 Thunder carb. 60303 VooDoo degree'd in at 105 1966 Coronet sedan 4 speed 3.91's Broken in properly. The engine (cam) is a pig on the bottom, comes on about 2500rpm and then seems to peak at approx. 4k and falls on it's face. A friend also installed same cam (yes degree'd in at the reccomended 106) in a fairly fresh 440 (10.3:1 cc's compression) 727 auto car with 3.23's and it acts/repsonds about the same way, pig on the bottom (car hardly brake torque the tires loose) comes on approx. 2500 rpm and then falls on it's face around 4k. We are pretty disappointed. Did much research for 9 months or more, read the limited feedback that was available and thought we had a winner here. You would think (and from previous experience) that a fresh 440 (both of ours) would roast the tires at will. What gives? I will be puling mine out and replacing it this winter. Not sure with what yet. Anyway other shared experiences would be appreciated...
Re: VooDoo cam experience [Re: Bob_Fromm] #516744
11/05/09 05:57 PM
11/05/09 05:57 PM
SW Fla.
CYACOP Offline
CYACOP  Offline
SW Fla.
Sounds like timing advance could be your issue. I read up on that cam and most people who had it liked it. I didnt go with it but it did make second choice for my application.
Re: VooDoo cam experience [Re: CYACOP] #516745
11/05/09 06:47 PM
11/05/09 06:47 PM
Montana
P
Posest Offline
Posest  Offline
P
Montana
I agree , there is something out of wack. I have the Voodoo in my 408 and love it.
Re: VooDoo cam experience [Re: Bob_Fromm] #516746
11/05/09 06:59 PM
11/05/09 06:59 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I run the 60303 cam in my low CR 440 and it does well. Just ask the kid at work who was grin from ear to ear on saturday when I drove my car to work and did a hard launch(no brakes, just throttle to the floor) right in front of him and left a wall of smoke behind me. I too am running 440source heads w/ the valve springs that came with them. Cheapie headers and for now a stock spreadbore dual plane intake with a thermoquad. Stock 727, stock converter and suregrip w/ 3.55 gears. When I nail the throttle hard from a stop, it breaks both rear tires loose and the back end goes sideways. I would say peak torq is 4000rpm with this cam in my combo, but it still pulls good to 5500. I would expect better top end and mid-range from your 10:1 440.
I do find mine loves a ton of initial ignition advance, the more the better. But I attributed that to having this cam with a low CR, not to the cam design itself. I think my combo with a 3000rpm converter and 4.10's would really make it haul in the bottom end and that's in the plans.
If my low CR 440 can do well with this cam, then if your 10:1 440 isn't a ground-pounder with this cam something is wrong, and I doubt it's the cam. FWIW I spent a fair amount of time tinkering with the distributor and I know it's not ideal yet. Also I tune with a wideband o2.
Have you done a compression check? Where are your numbers at?
Re: VooDoo cam experience [Re: DaytonaTurbo] #516747
11/05/09 08:08 PM
11/05/09 08:08 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
I do not run this cam, however initial timing is critical.
I had issues with my car not leaving properly and slow 60' times (high 1.4's - low 1.5's) for waaay toooo long! After beating my head against the wall I limited the advance in the distributor and put 20* initial timing in it and 37* total (you may require diffrent).
Wow what a difference Now my best 60' is 1.389 with consistant 1.40's.
If it falls off after 4,000 rpm then you might have a fuel delivery problem.
My car would hardly lift the tires 3" before, now look!
Re: VooDoo cam experience [Re: Bob_Fromm] #516748
11/05/09 08:51 PM
11/05/09 08:51 PM
Kirkland, Washington
Pacnorthcuda Offline
Bob--I run the 60303 in:
70 'Cuda
4 speed
3.55
850dp
906's
Eddy rpm
supposedely 10:1
18 initial, 34-36 total.
Cam installed at 106.5
Powerband comes on suddenly at 2000rpm, pulls hard. Haven't found the ceiling yet but its over 5600. Your's falls off at 4000? Somethings wrong.
Lunati will tell you that 104 is the min recommended install. I may actually re-do mine to 104.5 just to drop the p-band down a bit but by no means is it a dog on the bottom. I can fry my 275/50's at under 2500 with just a little bit of extra right foot.
Re: VooDoo cam experience [Re: roadhazard] #516749
11/05/09 08:54 PM
11/05/09 08:54 PM
British Columbia
chrisf Offline
chrisf  Offline
British Columbia
i am running the 60302 cam in my 383. 10-1 compression, rpm intake, 440source heads with good valvesprings, 750 vac. 2500stall 727 3.23's.
pulls well and i am very happy with it so far builds good power and rev's super quick.
Re: VooDoo cam experience [Re: chrisf] #516750
11/05/09 09:10 PM
11/05/09 09:10 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
That is a medium mild cam. my guess first off would be vacuum advance hooked up to manifold vacuum.
First off vacuum advance should never be hooked up till all your other tuning is done. my second guess is stock distributor springs not allowing what little mechanical advance to come on till 3500 or so.
so say this is the first too problems say you have 35 total but that total includes 20 deg of manifold vacuum and the 20 deg of mechanical is not all in till 3500. So that puts you pre start up initial at -5 deg. At WOT there is no vacuum so when you floor it at 2000 rpm the vacuum advance is gone and if all you have is a slow curve mechanical left you are probably at 5 deg of advance or so and that is so slow. then as your rpms increase to past 4000 the motor needs advance but you may be at 15 deg of total advance so no go either.
I could be wrong but I seen this lots!!
I would unhook and plug vacuum. set total to 38 deg with lighter advance springs having it all in by 2000 to 2200. when ypu have it all tuned in right see how it works. then and only then vacuum goes to the ported vacuum and any pinging is tuned out of the vacuum pot with a 3/32 allen wrench (in through vacuum pot) going counter clockwise till you have no ping under all types of driving!
Re: VooDoo cam experience [Re: DaytonaTurbo] #516751
11/05/09 10:17 PM
11/05/09 10:17 PM
Cookeville
Chilort Offline
Will Work For Mopars
Chilort  Offline
Cookeville
DaytonaTurbo, how much initial are you running?
I am getting ready to install a 60303 in my 440 that should be around 8.7:1 CR (calculated).
This is a great thread!
Re: VooDoo cam experience [Re: Chilort] #516752
11/05/09 11:35 PM
11/05/09 11:35 PM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
Kinda sounds like you did your degreeing on the exhaust and not the intake lobe maybe
Doesn't the voodoos have a split in/ex centerline?
Like 106 intake 110 exhaust. Just wondering
Re: VooDoo cam experience [Re: Mopar-Al] #516753
11/06/09 01:04 AM
11/06/09 01:04 AM
Wis., USA
Wis., USA
Thanks guys. Here's the answers to the questions I've ssen so far: Distributor: It is the mopar hemi race unit no vacuum advance all in by 2k easily. Cam was degree'd to 105 centerline believe Lunati asks for 106. It's a true 10.2:1 compression cc'd engine. I built the engine myself with my best friend who is Old Racer on here. He has built mopar engines for many years, many for Al Corda and has raced NSS class for years and won a few times such as the Mopar Nat's this year and the Hemi shoot out in 95 and max-wedge class runner-up in 96. So we have some experience but are not above looking for some help in this issue. Also with the 2 similar 440's and similar results we are a bit baffled. I believe your guys good experience with this cam as it should just fry the tires especially with my compression and 4 speed. The 65 Satellite has a bit better than stock convertor but is still a bit of a pig on the bottom. I have also tried a 750 Edelbrock that I have had for years and dialed it in on my old 440 so it ran well and also tried a 750 Holley double pumper off a friends ruinning engine, same results with both carbs. Keep the suggestions coming Thanks
Re: VooDoo cam experience [Re: Chilort] #516754
11/06/09 01:20 AM
11/06/09 01:20 AM
Manitoba, Canada
Manitoba, Canada
I'm running as much initial advance as I could before the engine started to fight against the starter. Honestly I don't know what the actual amount is. When I first fired the motor after the cam swap I baselined it to 12* just to get it running. Then I upped it to 16 and from there I put the timing light away and just tweaked it by hand until I got as much as I could before it would resist being turned over. Should have checked it afterwards but it runs well so I've left it. But then I've also been running it on pump 94 octane so I'm sure it would tolerate all the timing in the world!
Re: VooDoo cam experience [Re: DaytonaTurbo] #516755
11/06/09 01:26 AM
11/06/09 01:26 AM
Hello Bob. I'd see what your (cranking) compression is for a baseline. then as said "timing"
Re: VooDoo cam experience [Re: RapidRobert] #516756
11/06/09 03:04 AM
11/06/09 03:04 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
check you cranking psi, sounds like something other than the cam. a 2bbl 383 cam in a engine like yours will still roast the tires and pull past 4k
Re: VooDoo cam experience [Re: ademon] #516757
11/06/09 09:18 AM
11/06/09 09:18 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
what does the rest of your ignition system look like? maybe it's a problem with weak spark/voltage drop ahead of the coil?
2017 Grand Cherokee Overland
Re: VooDoo cam experience [Re: Bob_Fromm] #516758
11/06/09 09:57 AM
11/06/09 09:57 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
That is strange they should have lots of grunt from 2000 to 5600 set up like that.
Did you check the damper to see if timing marks are in faze? (they are well know for outer ring moving but not likely on two differnt cars.)
I too would like to see a compression test.
Poor spark maybe??
Did the same guy degree both cams and does he have lots of experience??
It is really strange as you have two engines both performing poorly in two different cars that would have two different fuel systems, two ignition systems two different torque converters and so on but only one common denominator the cam and maybe who degreed it and how it was degreed?? both should work great at 106 or 105 and that is not enough difference to feel??
Now if the exhaust was degreed at 105 the intake would be 115 and that would make them lazy @$$ motors??
Re: VooDoo cam experience [Re: Dodgem] #516759
11/06/09 10:07 AM
11/06/09 10:07 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
You could degree the cam fazing on every cylinder to see if you got cams that are not right. check the @ .050 events and all degree the intake and exhausts and that will give you the LSA and all??
If your cam is degreed properly you should have between 180 and 190 cranking compression with that cam!
Re: VooDoo cam experience *DELETED* [Re: Bob_Fromm] #516760
11/06/09 02:08 PM
11/06/09 02:08 PM
Tucson, AZ
cruzin Offline
cruzin  Offline
Tucson, AZ
Post deleted by cruzin
Re: VooDoo cam experience [Re: cruzin] #516761
11/06/09 04:33 PM
11/06/09 04:33 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Timing being all in by 2K doesn't mean squat if you don't have enough initial. how's that going to work if the distributor has 24-26 mechanical... not well with your set up.
Low intial will make an engine really lazy down low, poor throttle response, dirty idle. Probably needs a minimum of 15-18 initial and the rest in mechanical.
I'd double check the cam timing too..
Re: VooDoo cam experience [Re: RobX4406] #516762
11/06/09 07:38 PM
11/06/09 07:38 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
I was even able to close down my throttle plates after I put some INITIAL Timing in it and REALLY CLEAN UP MY IDLE!
