'69 B-Body Sway Bar Brackets? #516373
11/04/09 11:58 PM
11/04/09 11:58 PM
Phoenix, AZ
MCTPhoenix Offline OP
Phoenix, AZ
Does anyone reproduce the metal sway bar brackets for the 68 & 69 B-bodies ? The ones the rubber bushings go in. Thanks !
Re: '69 B-Body Sway Bar Brackets? [Re: MCTPhoenix] #516374
11/05/09 12:45 AM
11/05/09 12:45 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
If you are talking about the ones that bolt onto the K-member, no. Those are not reproduced. And when they get smashed it's REALLY hard to get the poly inserts shoved in there. Most cut and reweld them in. BUT if yours are smashed even that won't work.
BUT if you are talking about the tabs that weld onto the lower control arm, those are reproduced by Hotchkis.
http://www.hotchkis.net/early_mopar_control_arm_bracket.html
Re: '69 B-Body Sway Bar Brackets? [Re: autoxcuda] #516375
11/07/09 12:36 AM
11/07/09 12:36 AM
Phoenix, AZ
Phoenix, AZ
Looking for the ones that nobody reproduces yet. Such a commonly damaged part I'm surprised it hasn't been done yet.
Re: '69 B-Body Sway Bar Brackets? [Re: MCTPhoenix] #516376
11/07/09 12:58 AM
11/07/09 12:58 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Does it have to look stock or are you looking for something that functions, but doesn't have to look stock at all?
Re: '69 B-Body Sway Bar Brackets? [Re: autoxcuda] #516377
11/07/09 08:58 AM
11/07/09 08:58 AM
sixbbl69 Offline
sixbbl69  Offline
that is why you should have 6 sway bars hanging on wall for 30 yrs.
