Fresh 440 start up overheating? #516324
11/04/09 10:13 PM
11/04/09 10:13 PM
IL
hemiclone Offline OP
mopar addict
mopar addict
IL
Just Started up my rebuilt 440, everything is looking good except I had to shut it down after 8 minutes due to overheating. The temp got up to 200 before I shut it off, the upper hose and very top of the radiator was hot and full of pressure the rest of the radiator and the lower hose were cold. My first thought of course was a bad thermostat but I was wondering if it could be air bound? Thanks for any help!
Re: Fresh 440 start up overheating? [Re: hemiclone] #516325
11/04/09 10:22 PM
11/04/09 10:22 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Could have very easily been air locked. I always(when it is do-able)fill engine through thermo opening till it's about to spill over, then install the thermo and cover, top off rad a little , then start it.
Re: Fresh 440 start up overheating? [Re: buildanother] #516326
11/04/09 10:28 PM
11/04/09 10:28 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
I also leave the cap off so it can burp when the stat opens and leave some room on the top for expansion and save a little on mess.
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Re: Fresh 440 start up overheating? [Re: hemiclone] #516327
11/04/09 10:31 PM
11/04/09 10:31 PM
I'd prefer to keep the stat out for the breakin. Your timing is in the ballpark? A shop fan in front of the rad?
Re: Fresh 440 start up overheating? [Re: RapidRobert] #516328
11/04/09 10:36 PM
11/04/09 10:36 PM
IL
mopar addict
mopar addict
IL
Timing is close but not yet checked with a time light. I have the stock fan and shroud on
Re: Fresh 440 start up overheating? [Re: RapidRobert] #516329
11/04/09 10:38 PM
11/04/09 10:38 PM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
Also, no coolant just water
Re: Fresh 440 start up overheating? [Re: hemiclone] #516330
11/04/09 10:52 PM
11/04/09 10:52 PM
I would highly suggest checking it as too slow of timing will overheat it.
Re: Fresh 440 start up overheating? [Re: hemiclone] #516331
11/04/09 10:55 PM
11/04/09 10:55 PM
Hunt Valley, Maryland
1fastrunner Offline
1fastrunner  Offline
He meant an additional fan, like a shop fan or even one from your house to blow through the radiator or even just to keep air moving through the engine bay
Re: Fresh 440 start up overheating? [Re: RapidRobert] #516332
11/04/09 10:56 PM
11/04/09 10:56 PM
IL
mopar addict
mopar addict
IL
Don't forget the water is not flowing through the radiator so would timing do any good?
Re: Fresh 440 start up overheating? [Re: hemiclone] #516333
11/04/09 11:07 PM
11/04/09 11:07 PM
I'd pull the stat, set a big powerful fan in front of the rad, hookup your timing light & here is some excellent info on ring breakin. "break in secrets" at www.mototuneusa.com. I'd grab a helper (or 2) & have him man the light & twist the dist to get 36 at 2500 rpm. If you have not shortened your slots this will make your initial way off but for breakin you will NOT be below 2500 & I would goose the throttle many times during the 30 min breakin. (read "breakin secrets" & see what you think).
Re: Fresh 440 start up overheating? [Re: hemiclone] #516334
11/05/09 01:30 AM
11/05/09 01:30 AM
Colo Springs, Co
dragaddict Offline
super street
dragaddict  Offline
super street
Colo Springs, Co
Radiator could have been partially blocked and now you are building heat with a fresh engine. If you can run your hand across the front of the radiator safely while the engine is heating up and find a spot where the radiator gets hotter then cold you have a blockage. You have to do this before the whole thing heat soaks and is under 120 degrees to use your hand. Works on trucks every time. Also with the cap on if the lower hose seems collapsed and top has pressure at a higher idle same diagnoses. Water pump draws from the bottom and a blocked radiator will cause a restiction vacume.
