Front caliper & spindel A body #516311
11/04/09 10:12 PM
11/04/09 10:12 PM
pa
demongup Offline OP
demongup  Offline OP
pa
I have a 73 duster, disc brake spindel. I am looking to move the wheel in approx 1 inch.
Must have stopping power. Car is heavy .
Does not have to be a light weight set.Any stock type rotor have an offset like this ?
If not,who do you like ?
Anyone have a used set up?
Re: Front caliper & spindel A body [Re: demongup] #516312
11/04/09 11:27 PM
11/04/09 11:27 PM
It is probally cheaper to buy a new set of front wheels with the offset you need instead of replacing the rotors, calipers and mountning brackets
Re: Front caliper & spindel A body [Re: Cab_Burge] #516313
11/04/09 11:46 PM
11/04/09 11:46 PM
pa
demongup Offline OP
demongup  Offline OP
pa
No can do . I have 2 sets of matching rear rims ,1 pair is double beedlocks.The matching fronts were only avalible with a 1-3/4 offset
Re: Front caliper & spindel A body [Re: demongup] #516314
11/04/09 11:51 PM
11/04/09 11:51 PM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
Are you using an aftermarket rotor now? Some aftermarket brake rotors, like Wilwood, etc. tend to move the wheel offset outwards...
Re: Front caliper & spindel A body [Re: demongup] #516315
11/04/09 11:53 PM
11/04/09 11:53 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
IIRC, the 68-72 K-H discs had a narrower track than the 73 and up.
Re: Front caliper & spindel A body [Re: slantzilla] #516316
11/04/09 11:57 PM
11/04/09 11:57 PM
pa
demongup Offline OP
demongup  Offline OP
pa
I am not sure which one's you are talking about?
are they avalible still?do i have to change upper and lower control arms?
Re: Front caliper & spindel A body [Re: Sixpak] #516317
11/04/09 11:58 PM
11/04/09 11:58 PM
pa
demongup Offline OP
demongup  Offline OP
pa
stock
Re: Front caliper & spindel A body [Re: demongup] #516318
11/05/09 12:06 AM
11/05/09 12:06 AM
The 1968 to 1972 A bodys with the Kelsey Hayes four piston calipers did use a smaller ball joint on the lower control arms and upper A arms, different rotors and a different spindle than the later 1973 to 1976 A bodys did As far as the track widths
Re: Front caliper & spindel A body [Re: Cab_Burge] #516319
11/05/09 07:30 AM
11/05/09 07:30 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
I have a '76 Duster disc brake car. I seem to recall that the late disc brakes are about 3/4" wider per side. It has to be in the rotor/spindle itself, because the control arms are the same length. I know the front wheels stick way out on the car.
Re: Front caliper & spindel A body [Re: slantzilla] #516320
11/05/09 09:06 AM
11/05/09 09:06 AM
pa
demongup Offline OP
demongup  Offline OP
pa
I called Aero space this morning.
The can make a new rotor.They are not sure how far it can be offset until they see a stock setup.
Rotor and caliper around 1,000.Anyone got a grand I can borrow.lol
Re: Front caliper & spindel A body [Re: demongup] #516321
11/05/09 09:49 AM
11/05/09 09:49 AM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
As Slantzilla said, the '73-'76 OEM disc brakes has a wider track than the '72-earlier OEM KH disc or all of the OEM drum brakes.
Why buy more expensive custom parts? If you need a replacement, you'll need to get custom again.
Use a '73-'76 9' or 10" drum brake spindle and an off the shelf disc brake kit from Wilwood or AeroSpace. I think you will have a bigger brake selection with the 10" spindle. A '72-down spindle will work but you will need the '72-down upper A arm also (the ball joint size increased in '73).
Re: Front caliper & spindel A body [Re: B5 Bee] #516322
11/05/09 11:14 AM
11/05/09 11:14 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
For what its worth you can reem out the older spindles to the larger ball joint. I did this when I put my RMS upper arms on.
68 Barracuda Formula S 340
Re: Front caliper & spindel A body [Re: B5 Bee] #516323
11/05/09 01:15 PM
11/05/09 01:15 PM
pa
demongup Offline OP
demongup  Offline OP
pa
OK thanks for the help .
Considering I tossed all my front drums spindels and upper and lower arms....does anyone have a donor set?
