Re: Front caliper & spindel A body
[Re: Cab_Burge]
#516313
11/04/09 11:46 PM
11/04/09 11:46 PM
Posts: 414 pa
demongup
pa
It is probally cheaper to buy a new set of front wheels with the offset you need instead of replacing the rotors, calipers and mountning brackets
No can do . I have 2 sets of matching rear rims ,1 pair is double beedlocks.The matching fronts were only avalible with a 1-3/4 offset
[Re: demongup]
#516315
11/04/09 11:53 PM
11/04/09 11:53 PM
Posts: 20,172 Park Forest, IL
slantzilla
Park Forest, IL
IIRC, the 68-72 K-H discs had a narrower track than the 73 and up.
[Re: slantzilla]
#516316
11/04/09 11:57 PM
11/04/09 11:57 PM
Posts: 414 pa
demongup
pa
I am not sure which one's you are talking about? are they avalible still?do i have to change upper and lower control arms? Thanks
[Re: Sixpak]
#516317
11/04/09 11:58 PM
11/04/09 11:58 PM
Posts: 414 pa
demongup
pa
Are you using an aftermarket rotor now? Some aftermarket brake rotors, like Wilwood, etc. tend to move the wheel offset outwards...
stock
[Re: Cab_Burge]
#516319
11/05/09 07:30 AM
11/05/09 07:30 AM
slantzilla
Park Forest, IL
I have a '76 Duster disc brake car. I seem to recall that the late disc brakes are about 3/4" wider per side. It has to be in the rotor/spindle itself, because the control arms are the same length. I know the front wheels stick way out on the car.
[Re: B5 Bee]
#516322
11/05/09 11:14 AM
11/05/09 11:14 AM
Posts: 8,021 Tulsa OK
Bad340fish
Tulsa OK
For what its worth you can reem out the older spindles to the larger ball joint. I did this when I put my RMS upper arms on.
68 Barracuda Formula S 340
