SMALL BLOCK PARTS THAT WORK WITH BIG BLOCK ???? #516139
11/04/09 08:14 PM
11/04/09 08:14 PM
Pittsburgh area
BIGJOE30 Offline OP
BIGJOE30  Offline OP
Pittsburgh area
OK CAN ANYONE HELP ME? I HAVE THESE SMALL BLOCK PARTS LYING AROUND DOING NOTHING.
WILL A SMALL BLOCK DISTRIBUTOR WORK IN A 383, 400
ALSO AS FAR AS PULLEYS GO, ARE THE WATER PUMP
AND THE CRANK PULLEYS INTERCHANGEBLE? I HAVE 2 WATER PUMP AND I HAVE 2 AND 3 GROOVE CRANK ALL OFF 318S AND 360S.
ALSO I KNOW THE ALTERNATOR BRACKET IS DIFFERENT BUT IS THE SPACERS DIFFERENT? I WOULDNT THINK SO.
THANKS FOR ANY HELP
Re: SMALL BLOCK PARTS THAT WORK WITH BIG BLOCK ???? [Re: BIGJOE30] #516140
11/04/09 08:16 PM
11/04/09 08:16 PM
Lima, Peru
domingo Offline
EL Master
domingo  Offline
EL Master
Lima, Peru
NOTHING INTERCHANGES...MAYBE A COUIPLE BOLTS.
Re: SMALL BLOCK PARTS THAT WORK WITH BIG BLOCK ???? [Re: domingo] #516141
11/04/09 08:19 PM
11/04/09 08:19 PM
Pittsburgh area
BIGJOE30 Offline OP
BIGJOE30  Offline OP
Pittsburgh area
NOT EVEN THE ALT. SPACER TUBES??
Re: SMALL BLOCK PARTS THAT WORK WITH BIG BLOCK ???? [Re: BIGJOE30] #516142
11/04/09 08:26 PM
11/04/09 08:26 PM
The one inside the alt mounting tabs would for sure
Re: SMALL BLOCK PARTS THAT WORK WITH BIG BLOCK ???? [Re: RapidRobert] #516143
11/04/09 08:30 PM
11/04/09 08:30 PM
Pittsburgh area
BIGJOE30 Offline OP
BIGJOE30  Offline OP
Pittsburgh area
thats what i thought, what is different about the pulleys though??
Re: SMALL BLOCK PARTS THAT WORK WITH BIG BLOCK ???? [Re: BIGJOE30] #516144
11/04/09 08:35 PM
11/04/09 08:35 PM
Joe I could of sworn the other day someone had a (iirc crank) pulley or set (wp/crank) for sale here that was advertised for big or small block
Re: SMALL BLOCK PARTS THAT WORK WITH BIG BLOCK ???? [Re: RapidRobert] #516145
11/04/09 08:40 PM
11/04/09 08:40 PM
Pittsburgh area
BIGJOE30 Offline OP
BIGJOE30  Offline OP
Pittsburgh area
i put the crank pulley on my damper it lines up fine why would this not work?? same for waterpump.
Re: SMALL BLOCK PARTS THAT WORK WITH BIG BLOCK ???? [Re: RapidRobert] #516146
11/04/09 08:41 PM
11/04/09 08:41 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Pulleys would be a crap shoot. The bolt pattern would be the same but it would depend on the offset & diameter needed.
No way for the distributor.. The advance is oposite for one thing.
Re: SMALL BLOCK PARTS THAT WORK WITH BIG BLOCK ???? [Re: MoparforLife] #516147
11/04/09 08:45 PM
11/04/09 08:45 PM
Pittsburgh area
BIGJOE30 Offline OP
BIGJOE30  Offline OP
Pittsburgh area
thats what i was worried about on the pulleys
i figured the bolts would align but was worried about the belts. i just dont want to get rid of them if they will work but at the same time want rid of them if there small block.
Re: SMALL BLOCK PARTS THAT WORK WITH BIG BLOCK ???? [Re: BIGJOE30] #516148
11/04/09 09:00 PM
11/04/09 09:00 PM
Upper Midwest
Upper Midwest
Oh yeah the starter will bolt up too.
Re: SMALL BLOCK PARTS THAT WORK WITH BIG BLOCK ???? [Re: MoparforLife] #516149
04/28/10 03:27 AM
04/28/10 03:27 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Distributor caps and rotors interchange, as do some water temp sending units, oil pressure sending units, thermostats, some spark plugs...
Re: SMALL BLOCK PARTS THAT WORK WITH BIG BLOCK ???? [Re: Kern Dog] #516150
04/28/10 09:51 AM
04/28/10 09:51 AM
On the pulleys the groove would be the same so if the dia/offset will work for your BB your good and if not might measure what you have and put them in the for sale section & see if you can lose em that way
