Does an engine with two carbs
#516053
11/04/09 05:46 PM
11/04/09 05:46 PM
Posts: 5,906 Athens, Greece
Pyper70
Athens, Greece
Need an electric fuel pump to operate correctly?
I have the stock Carter from Mazzolini, will it be enough to feed dual 500 edelbrocks?
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: Does an engine with two carbs
[Re: RapidRobert]
#516055
11/04/09 06:58 PM
11/04/09 06:58 PM
Pyper70
Athens, Greece
if street yes easily, more info: what eng, how much HP, rpm range, street or strip
440, 280/480 Isky megaCam, I usually drive up to 4000rpm...I dont get too crazy....maybe 5000 if I play a little. Street...What else do I need to post...Installing aluminum eddy's this winter and blockhugger headers
[Re: RapidRobert]
#516057
11/04/09 07:24 PM
11/04/09 07:24 PM
Pyper70
Athens, Greece
Sweet.....Cuz I dont wanna start running 1/2" line to the tank....I have a 3/8" feed now with no return line...
Should I install a return line? Just asking though...If I have two carbs sucking down fuel, there will be nothing left to send back hahahaha
[Re: Pyper70]
#516058
11/04/09 07:35 PM
11/04/09 07:35 PM
RapidRobert
1st order of business would be to add (temporarily if need be)(with an isolator of course ) a 0-15 fuel psi gauge on the dash and see if you have several psi at the end of the street . A return line keeps the fuel to the carb cooler since it is getting more cooler fuel from the tank instead of just the stagnant fuel present in the line and is an excellent plan w an electric pump to keep it from deadheading but in your case to K.I.S.S. keep the lines away from the ex and/or some insulation and you'll be fine.
