11/04/09 11:21 AM
11/04/09 11:21 AM
sweden
the swede Offline OP
sweden
Hi guys I was thinking of building a stroker motor with w2 heads maybe a k1 forged 4.00 inch crank and kb forged pistons and using a camshaft that will lift around 590.What do you think guys can this work i would like to have somewhere around 500 to 550 hp.Or does anyone else have a better idea?
Thanks Mats.
Re: 318/390 [Re: the swede] #515790
11/04/09 12:59 PM
11/04/09 12:59 PM
organ
maximum entropy Offline
organ
i've always wanted to do a 318 stroker. you may be limited by the small bore size, but 550 hp should be easy, i would think. what kind of fuel are you going to run? w2s and a mild roller would get you there with a little compression.
Re: 318/390 [Re: maximum entropy] #515791
11/04/09 01:14 PM
11/04/09 01:14 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
how far can the 318 block be bored?
Re: 318/390 [Re: maximum entropy] #515792
11/04/09 02:26 PM
11/04/09 02:26 PM
sweden
sweden
Im going for shell v-power 99 octan I think
Re: 318/390 [Re: mopar dave] #515793
11/04/09 02:30 PM
11/04/09 02:30 PM
sweden
sweden
318 Block from 68 has thicker cylinder walls Ive heard and I have a friend that bored his block 4.040 and he run that engine for a couple of years without any problem
Re: 318/390 [Re: the swede] #515794
11/04/09 02:38 PM
11/04/09 02:38 PM
Northwest Chicago Suburb
DaDart Offline
DaDart  Offline
Check out THIS POST
I currently have a 318 stroked to 349 and it seems very peppy
3 Darts and a Ram
Re: 318/390 [Re: DaDart] #515795
11/05/09 01:25 AM
11/05/09 01:25 AM
San Angelo Tx
Alan Warman Offline
Alan Warman  Offline
San Angelo Tx
Here is our combo,it consist of all the parts that every one says not to use. It started with a 1968 block bored to 4.00". Mopar 3.55 crank local dealer had them on sale for 200.00. Eagle SIR rods ebay specials 179.00,KB pistons for a 360 I cant think the part # offhand but it makes about 11 to 1 comp ebay item 224.00. The cam is a Mopar 590 solid already had it. Heads are W2s ported to mopar templets,and Harland Sharp roller rockers 1.5. A Holley intake with a 750DP. Step headers 2 1/8",DOWN TO 2" down to 1 7/8". In our 70 Dart it has run 10.60s at 125mph and that's at 5500ft DA. The car weighs 3200lb with driver,904 trans w/brake gears are 4:88s.
Alan Warman STK 4107
Re: 318/390 [Re: mopar dave] #515796
11/05/09 01:40 AM
11/05/09 01:40 AM
Las Vegas, NV
dodgeboy11 Offline
dodgeboy11  Offline
Las Vegas, NV
Get the block sonic checked. Then you'll know how far it can go.
Re: 318/390 [Re: dodgeboy11] #515797
11/07/09 03:04 PM
11/07/09 03:04 PM
sweden
sweden
Im going to sonic test my block but its not going to be easy to find someone who can do it here in sweden
Re: 318/390 [Re: the swede] #515798
11/08/09 06:06 PM
11/08/09 06:06 PM
Stockholm,SWEDEN
The Nutcracker Offline
Stockholm,SWEDEN
Svea bil i ulvsunda i Stockholm ska kunna göra det.
-70 Cuda,-65 Valiant,-66 Valiant,-62 FED
Re: 318/390 [Re: mopar dave] #515799
11/08/09 07:26 PM
11/08/09 07:26 PM
.030-.040 i would imagine.
Re: 318/390 [Re: The Nutcracker] #515800
11/11/09 04:49 AM
11/11/09 04:49 AM
sweden
sweden
Ok tack för det ska kolla med dom
