Externally balanced 440 and aftermarket flywheel #515756
11/04/09 05:03 AM
11/04/09 05:03 AM
Hawaii
Dodgeballs Offline OP
Hawaii
I have a Hays 11-340 flywheel which is neutral balanced (I believe), but my 440 is a 1970 HP externally balanced. Can the flywheel be weighted for the motor and if so, how? Or is there another option I should be looking at?
I also have a '69 stock 440 flywheel - but I think it is neutral balanced as well. Only the six pack 440's were externally balanced in 69, right?
Man, this 4 speed conversion is frying my brain already. But nothing like side-stepping the clutch and power shifting. It's been too long.
Re: Externally balanced 440 and aftermarket flywheel [Re: Dodgeballs] #515757
11/04/09 08:00 AM
11/04/09 08:00 AM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
It's my belief that your 1970 crank is steel and does not need external balancing unless it's from the 6 pack engine.
Also, does the end of the crank have the pilot hole to receive the 4 speed?
Re: Externally balanced 440 and aftermarket flywheel [Re: Commando1] #515758
11/04/09 08:23 AM
11/04/09 08:23 AM
an8sec70cuda Offline
1970-1972 HP 440's were externally balanced. They all had 6 pack rods, even the 4 barrel versions. If I am not mistaken, the '69 1/2 6 pack motors were internally balanced b/c they had LY rods. Doesn't matter if the crank is steel or cast, if it has 6 pack rods then it's externally balanced.
Just went through this on my dad's road runner. I had the rotating assembly internally balanced, it was a 1971 HP 440 w/ 6 pack rods (external balanced motor). Makes changing flywheels later on down the road much easier. CHIP
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Externally balanced 440 and aftermarket flywheel [Re: Dodgeballs] #515759
11/04/09 02:06 PM
11/04/09 02:06 PM
Hawaii
Hawaii
Thanks for the responses.
So am I screwed?
Can only the original flywheel for the motor be used (which I don't have because my motor had an auto trans originally) unless I pull the rotating assembly and get it all rebalanced?
Re: Externally balanced 440 and aftermarket flywheel [Re: Dodgeballs] #515760
11/04/09 04:49 PM
11/04/09 04:49 PM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
You might be screwed eventually, but not yet.
Old trick is to install the neutral flywheel, then weld the appropriate weight onto teh pressureplate housing. I've never had to do it, but I've heard of doing it. You'll have to research that one further.
The old-school reports were that all steel cranks were drilled for a manual trans, but I've heard of enough exceptions over the years that I would verify mine before trying to throw a trans in the car. If yours isn't drilled, Napa has a 'conversion' bearing that fits into the outer section of the crank hub. You'll have to research that one too.
Parts I seek: driver doorpanel, 65 Sport Fury, prefer black, needs to be 7-8 on 10 scale, might buy set 16" x 6" Dodge truck wheel(s), from early 70s?, takes 9" dogdish - need for a research job so cheaper is better. 69-73 C-body caliper brackets and/or splashields Send a PM.
Re: Externally balanced 440 and aftermarket flywheel [Re: Dodgeballs] #515761
11/04/09 05:01 PM
11/04/09 05:01 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The neutral balanced flywheel can be modified for the external balance needed for the heavy rods, this amounts to drilling some holes opposite the side that needs the weight. The top diagram in the pic below shows how:
Re: Externally balanced 440 and aftermarket flywheel [Re: Fury Fan] #515762
11/04/09 05:12 PM
11/04/09 05:12 PM
As far as I know, the only way to balance the flywheel for this application is to have the rotating assembly out of the motor.
Like Fury Fan said, I have heard of welding weights to the pressure plate. That would be a pain b/c when it comes time for a new clutch and pressure plate, you'll be doing it over again.
In the long run I think you'll be better off internally balancing the motor. I know that's a pain for you with your motor running good and all.
There is a roller pilot bearing for cranks that never had a pilot bushing installed. That's what I used on my dad's car. I had a friend get me one through Mopar Performance. Sorry, I dont remember the part number for it.
With all the '70 and up 440 HP motors that had 4 speeds behind them, you'd think an externally balanced flywheel would be easy to come by. CHIP
edit...I think John Kunkel just saved the day, lol. Hope that works for ya!!
CHIP
Re: Externally balanced 440 and aftermarket flywheel [Re: John_Kunkel] #515763
11/04/09 08:45 PM
11/04/09 08:45 PM
Hawaii
Hawaii
Thank you John!
I assume that this procedure is for the 11" neutral balance flywheel?
Thanks again.
Re: Externally balanced 440 and aftermarket flywheel [Re: Dodgeballs] #515764
11/04/09 08:57 PM
11/04/09 08:57 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Passon and brewers will sell you a flywheel for an external balance 440. Also there's a weight kit/template out there for adding weights to a neutral balance torq converter. Someone posted once that they were able to add those weights to their flywheel successfully.
Re: Externally balanced 440 and aftermarket flywheel [Re: Dodgeballs] #515765
11/05/09 01:23 AM
11/05/09 01:23 AM
Hawaii
Hawaii
OK
New solution. 69 internally balanced motor. Thanks for all the help and info. If I knew it was this hard to use the 70 motor, I think I would have gone this route from the beginning. Sorry for being a pita. But thank you for the education!
Re: Externally balanced 440 and aftermarket flywheel [Re: Dodgeballs] #515766
11/05/09 09:48 AM
11/05/09 09:48 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Thank you John!
Thanks again.
Yes that procedure will work for both the 130 tooth or 143 tooth wheel .
Re: Externally balanced 440 and aftermarket flywheel [Re: JohnRR] #515767
11/05/09 11:57 PM
11/05/09 11:57 PM
Hawaii
Hawaii
Thanks for the clarification. I think both my cars are going 4 speed now
Thank you John!
Thanks again.
Re: Externally balanced 440 and aftermarket flywheel [Re: an8sec70cuda] #515768
11/06/09 12:26 AM
11/06/09 12:26 AM
eganville ont
440beep Offline
440beep  Offline
eganville ont
1972 440 hp is not externally balanced
is internally balanced and has 6 pack rods
1970 -71 440hp are externally balanced
Plymouth's gonna getcha! There are 3 things that will live forever, cockroaches, Keith Richards, & slant 6 Dusters 71 gtx 440 4speed air grabber blue on blue with white vinyl roof
Re: Externally balanced 440 and aftermarket flywheel [Re: 440beep] #515769
02/24/12 06:58 PM
02/24/12 06:58 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
I need to post on this to save it.
So this will work to put my 70 internall bal flywheel on a 74 externall motor ?
