Difference in Fan Clutch w/Rear Gear Ratio ?? #515706
11/03/09 11:34 PM
11/03/09 11:34 PM
Land of 10,000 Lakes
44D6PAKCUDA Offline OP
I was looking at an aftermarket fan clutch for my '70 340 Duster and noticed that they showed one fan clutch for a 340 car w/271/276 rear end gears and another clutch for 355/391 gears.What would be the difference?Both are showing to be a 6" diameter clutch.Why wouldn't they interchange?Just courious
Re: Difference in Fan Clutch w/Rear Gear Ratio ?? [Re: 44D6PAKCUDA] #515707
11/04/09 04:54 PM
11/04/09 04:54 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The factory parts book breaks them down the same way, one clutch is thermal, the other isn't.
Re: Difference in Fan Clutch w/Rear Gear Ratio ?? [Re: John_Kunkel] #515708
11/04/09 08:47 PM
11/04/09 08:47 PM
S.E. Conn
Hoof Hearted Offline
S.E. Conn
Good question.
B U M P.
2005 300C Hemi
2014 Ram ProMaster 2500
I Rekey, Repin old Chrysler locks and cut keys by code
Re: Difference in Fan Clutch w/Rear Gear Ratio ?? [Re: Hoof Hearted] #515709
11/04/09 11:31 PM
11/04/09 11:31 PM
So a thermal fan clutch has a raised center and a non-thermal clutch would be flat?
Re: Difference in Fan Clutch w/Rear Gear Ratio ?? [Re: 44D6PAKCUDA] #515710
11/05/09 10:22 AM
11/05/09 10:22 AM
Outing, MN
beesuperA12 Offline
beesuperA12  Offline
Outing, MN
In the aftermarket,most thermal fan clutches have a bi-metalic spring on the radiator side that changes the orifice that the fluid in the clutch flows through, increasing or decreasing drag. Non thermal rely on simple fluid friction.
69.5 Super Bee A12
Re: Difference in Fan Clutch w/Rear Gear Ratio ?? [Re: beesuperA12] #515711
11/05/09 09:27 PM
11/05/09 09:27 PM
Any idea if they would be interchangable with each other or any problems by putting say a thermal clutch on a car that calls for a non thermal clutch?
