alt PN research #515596
11/03/09 09:39 PM
11/03/09 09:39 PM
Valencia, España
NachoRT74 Offline OP
Valencia, España
found this PN on an alt
3780589
wrotte with a sharpie probably taken from box.
does somebody knows if is the right PN AND specs on alt ?
Pretty sure is at least 60 amps, but wishing will be more
Re: alt PN research [Re: NachoRT74] #515597
11/03/09 09:41 PM
11/03/09 09:41 PM
Valencia, España
Valencia, España
and no, is not at mymopar PN searching tool
Re: alt PN research [Re: NachoRT74] #515598
11/03/09 11:15 PM
11/03/09 11:15 PM
St Louis, Missouri
Runnin74 Offline
Runnin74  Offline
St Louis, Missouri
Looked that up in my parts book and it is a 60 amp alternator, double groove pulley, with stamped number 3755413, pulley number 3656571.
Re: alt PN research [Re: Runnin74] #515599
11/03/09 11:32 PM
11/03/09 11:32 PM
Valencia, España
Valencia, España
great!!! thanks
do you have some more PN about alts with more output ? this dealer have a some ones around and maybe I can find some one more with better output on 65-80 rate
Re: alt PN research [Re: NachoRT74] #515600
11/04/09 12:00 AM
11/04/09 12:00 AM
St Louis, Missouri
Runnin74 Offline
Runnin74  Offline
St Louis, Missouri
65 amp alternators -
single groove pulley pn 3755191 stamped number 3755192
double groove pulley pn 3755191 stamped number 3755191
86 amp alternator -
double groove pulley 3755585 stamped number 3755585
Re: alt PN research [Re: Runnin74] #515601
11/04/09 10:47 AM
11/04/09 10:47 AM
Valencia, España
Valencia, España
GRRRRRRRRRRRRRREAT... THANKS
some of them is labeled like Leece Neville alts or are all they standarts alts ?
Re: alt PN research [Re: NachoRT74] #515602
11/04/09 10:48 AM
11/04/09 10:48 AM
Valencia, España
Valencia, España
well forgett it, Leece Neville alts are really 100 amps as far I know.
thanks.
