904 selector shaft seal? #515434
11/03/09 06:15 PM
11/03/09 06:15 PM
Branson, Mo.
joedust451 Offline OP
super gas
super gas
Branson, Mo.
Where can you get these, what would be the part# if anyone knows?
Also, can these be removed without dropping the VB?
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
Re: 904 selector shaft seal? [Re: joedust451] #515435
11/03/09 06:30 PM
11/03/09 06:30 PM
scratchnfotraction Offline
I get them at napa or the local tranny shop and dont forget the dealer for a good mopar one
yes,they can be done that way. just not as easy of an install due to clearance at the floor pan
I drop the VB and use a bolt with some washers with a nut to pull it down in the hole
use a screw driver from the bottom when VB out to pop the old one out
I have dont them with the VB in by droping the xmember and tail down some and used a socket that fits over the shaft to drive the seal in with a hammer
dont for get the there is a small seal on the throttle pressure valve stem also,it has an e clip and is an easy one to do with the VB out
if its done with the VB in,dont let it drop down with the e clip off..
IMHO,just drop the VB and do both,less work and headache..
did you get the good reusable pan gasket from the dealer??? well worht the 15$ or so for it
I have reused mine about 6 times on 2 diff trannys
Re: 904 selector shaft seal? [Re: scratchnfotraction] #515436
11/03/09 06:54 PM
11/03/09 06:54 PM
much less aggravation
Re: 904 selector shaft seal? [Re: RapidRobert] #515437
11/03/09 07:11 PM
11/03/09 07:11 PM
Branson, Mo.
super gas
super gas
Branson, Mo.
The tranny is on the ground, going to install the engine/trans soon, maybe i'll just prop it up on stands & do the VB drop while its still out of the car, i DO want to get that good gasket (they are a god sent), i'll have to go about 35 miles to a tranny shop, maybe they will have those seals too.
Re: 904 selector shaft seal? [Re: joedust451] #515438
11/03/09 07:22 PM
11/03/09 07:22 PM
Wichita, KS
tmef Offline
tmef  Offline
Wichita, KS
Would anyone happen to know off hand the Chrysler PN's for both of the shaft seals and the reusable pan gasket?
Re: 904 selector shaft seal? [Re: scratchnfotraction] #515439
11/03/09 07:51 PM
11/03/09 07:51 PM
Minn
SportF Offline
SportF  Offline
Minn
Scratch, (or anybody else knowing 904's)do you know if the front seal on the 904 and the 727 are the same. I have a 904 leak in the front and the local NAPA guy says the front seals are the same. That doesn't seem right, but I bought one to put in this weekend. I have done this many times on the 727 in my race car, but I am not at home and would hate to do this on the week end and have it be the wrong seal. Please advise if you will, thanks!
Re: 904 selector shaft seal? [Re: SportF] #515440
11/03/09 07:54 PM
11/03/09 07:54 PM
BDW Online content
BDW  Online Content
You can definitely do it without dropping the pan. I did mine, here's the info you need.
https://board.moparts.org/ubbthreads/show...&PHPSESSID=
Re: 904 selector shaft seal? [Re: SportF] #515441
11/03/09 07:55 PM
11/03/09 07:55 PM
The shifter shaft seal is the same, not sure on the front pump seal
Re: 904 selector shaft seal? [Re: RapidRobert] #515442
11/03/09 09:13 PM
11/03/09 09:13 PM
I went out to the truck shed and Removed the seal from an 85 727 lock-up truck tranz
I removed the seal from a late 80s early 90s (I think a 90 model v-6 904 tranz from a van)
front pump seals are deff not the same on them 727 is larger..
I have the shaft seal from the dealer and cant see a number on it..
I have still in the dealer package a throttle pressure shaft seal and the # on the package are..1-02466548
and the dip tube o-ring is..1-06030608
I had a rect for the front seal,rear seal,shaft seal,TPV seal,pan gasket but tossed it...it was 3 yrs old..sorry
but I would say the pump seals are not the same for them,IMO
hope that helped out though
Re: 904 selector shaft seal? [Re: RapidRobert] #515443
11/03/09 09:16 PM
11/03/09 09:16 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
The front pump seal is NOT the same .
this trans is on the ground , the seal can be replaced without dropping the pan , carefully pull the seal , KD tools sells a tool to do it in the car and it would be easier with it out ogf the car even without the tool , and drive it back in with a deep socket ...
Re: 904 selector shaft seal? [Re: JohnRR] #515444
11/03/09 09:21 PM
11/03/09 09:21 PM
Minn
SportF Offline
SportF  Offline
Minn
Thanks guys on the front seal. I guess another trip to someplace else and then return the seal to NAPA. Better find out now than this weekend when I have to have this thing drivable by Monday.
Re: 904 selector shaft seal? [Re: SportF] #515445
11/03/09 09:33 PM
11/03/09 09:33 PM
when you return the seal to napa be sure to tell him thanks
ask him if he is a chivy guy selling dodge parts
