Reading methonal plugs? #515338
11/03/09 04:06 PM
11/03/09 04:06 PM
Cali S.B
Sub95 Offline OP
super gas
Sub95  Offline OP
super gas
Cali S.B
What should a NA methonal plug look like after a pass?.
Re: Reading methonal plugs? [Re: Sub95] #515339
11/03/09 04:13 PM
11/03/09 04:13 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Its hard to read a alky plug, from boarder line "rich" to boarder line "lean" the plugs look the same to me despite what EGT, or MPH says.
When you find out let me know...
here is a bump for ya..
I can tell you that with lots of squeeze and on alky, plug gaps doesnt like to be much wider than .035
I get the tune close, and tune for MPH the same way I do on gas.
When your close it will gain about 8 deg temp from launch to cross the finish line..You gotta look down fast, cause once your off the throttle the temps will fall fast...
I try to stage the car at or near 160..
Re: Reading methonal plugs? [Re: Sub95] #515340
11/03/09 10:02 PM
11/03/09 10:02 PM
gregsdart Offline
gregsdart  Offline
I use NGK plugs, go by how much plating is scorched on the plug plus exhuast temp readings. I was told you like to see about 2/3 of the plating scorched at the base of the plug, or the surface that is even with the chamber wall.
Re: Reading methonal plugs? [Re: gregsdart] #515341
11/04/09 06:54 AM
11/04/09 06:54 AM
ontario canada
mac56 Offline
mac56  Offline
ontario canada
I found that after only one run on a plug, if the plating has burnt off just down off the ground strap onto the top ring of the plug you are close. It is very hard to tell. They will tan up after a few runs if you are close. You can tell if it is rich because the plug looks washed but lean is another story even with egt gauge. I had good temp reading and leaned out. Took the porcelian right off the electrode.
Re: Reading methonal plugs? [Re: gregsdart] #515342
11/04/09 07:13 AM
11/04/09 07:13 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
NGK Have to be read after one run with the engine shutoff before the turn off. Have to use new plugs every run to be able to read them.I've read hundreds. I wanted to see 2 threads discolored.
Re: Reading methonal plugs? [Re: Challenger 1] #515343
11/04/09 11:52 AM
11/04/09 11:52 AM
gregsdart Offline
gregsdart  Offline
I guess you are building a bit more heat!
Re: Reading methonal plugs? [Re: Challenger 1] #515344
11/04/09 11:56 AM
11/04/09 11:56 AM
Quebec, Canada
Diablo Offline
Diablo  Offline
Quebec, Canada
With the new engine we are using NGK's and need to change hte plugs every run to read them. We were told to have the platinum 2/3 burnt off the plug. You can tell if the timing is good also by a small burn mark going up the neck of the plug.
What confuses me is what EGT i should have. Depending on who i talk to its anywhere from 1050 to 1250?????? That a big difference!
What was weird about our engine was one side was reading to rich where the other side was almost to lean.
Re: Reading methonal plugs? [Re: Sub95] #515345
11/04/09 07:40 PM
11/04/09 07:40 PM
SW WI
cudacustoms1 Offline
SW WI
What are you running for a motor.If you are running a weadge head don't try the 2 tread down as agood heat.I have been there! The max setting we found would show heat all the way aroud the top of the plug. If it's starting down to the treads get some more fuel in.Again this is on weadge head. Hemi is a whole diferent deal. Then the two thread deal is good.We backed my motor to where it was 3/4 around the plug.If you use top end lube it will make it harder to read also.There is a good article on dragstuff by mike canter about reading alcohol plugs.
Re: Reading methonal plugs? [Re: cudacustoms1] #515346
11/04/09 08:58 PM
11/04/09 08:58 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
My experiance is with a blown/injected BB Chevy which is still a wedge of sorts & we always looked for two threads...
Re: Reading methonal plugs? [Re: 1_WILD_RT] #515347
11/05/09 01:27 PM
11/05/09 01:27 PM
St. Charles, MO.
Slingshot383 Offline
St. Charles, MO.
If you're burning the tip of the electrode, you're lean!
1994 Undercover Chassis 125" altered stack injected big block, soon blown and injected Member of The Torque and Recoil Club
