Does anyone make headers for 66 Barracuda #515075
11/03/09 08:47 AM
11/03/09 08:47 AM
MD
75dusted Offline OP
75dusted  Offline OP
MD
Does anyone make headers for 1966 Barracuda and make a trans crossmember setup for dual exhaust, mine only has 1 cutout for single exhaust
Re: Does anyone make headers for 66 Barracuda [Re: 75dusted] #515076
11/03/09 08:50 AM
11/03/09 08:50 AM
MD
75dusted Offline OP
75dusted  Offline OP
MD
I have a 273 motor and auto trans
Re: Does anyone make headers for 66 Barracuda [Re: 75dusted] #515077
11/03/09 09:40 AM
11/03/09 09:40 AM
Northeast
mopar71RR Offline
mopar71RR  Offline
Northeast
Spitfire and TTI make headers for the 66 Cuda. Laysons sells a modified trans crossmember for dual exhausts. It is easy to modify the trans crossmember yourself. I believe instuctions may be found on internet or this website.
Re: Does anyone make headers for 66 Barracuda [Re: mopar71RR] #515078
11/03/09 10:45 AM
11/03/09 10:45 AM
with the crossmember in place trim it out to match the frame cutout on that side then take it back off & box it
Re: Does anyone make headers for 66 Barracuda [Re: 75dusted] #515079
11/03/09 11:54 AM
11/03/09 11:54 AM
BROWNSBURG, IN
speed service Offline
BROWNSBURG, IN
I would suggest TTI for your headers.. As far as the trans cross member. We use 4130 .195 c-channel on the cut out then weld the ends of the new cut out and the old cross member for a good strong member! Everybody needs a good strong member!!! lol
SPEED SERVICE 1500 E. MAIN STREET BROWNSBURG,IN 46112 1-317-858-7733 www.SPEEDSERVICESTORE.COM www.SPEEDSERVICELLC.COM
Re: Does anyone make headers for 66 Barracuda [Re: speed service] #515080
11/03/09 12:16 PM
11/03/09 12:16 PM
and a cold shower
Re: Does anyone make headers for 66 Barracuda [Re: RapidRobert] #515081
11/03/09 12:24 PM
11/03/09 12:24 PM
the house on the left.
cogen80 Offline
cogen80  Offline
spitfire- shortie tri Y design.
hooker - fenderwells
headman- fenderwells
dougs- under carriage (nice fitting)
tti- under carriage, need special expensive starter from what i understand.
just modify your current trans cross member. its easy.
Re: Does anyone make headers for 66 Barracuda [Re: cogen80] #515082
11/04/09 09:40 AM
11/04/09 09:40 AM
Finalnd, Perkele
jyrki Offline
jyrki  Offline
Finalnd, Perkele
Hooker-partial fenderwells #5208
Plynouth VIP '67 TT IC EFI
Re: Does anyone make headers for 66 Barracuda [Re: 75dusted] #515083
11/04/09 11:59 AM
11/04/09 11:59 AM
Owego, NY
JBurch Offline
JBurch  Offline
Owego, NY
Which headers you go with depends on what you want to do with your car.
I have observational experience with Spitfires, 2 friends are using them; one in a 65 Dart 273 4spd car, a drive it anywhere car, the owner loves them; the other is a 66 Barracuda, 318, auto, drag car that so far has gone 12.7's in the quarter, the owner likes them. I have a 65 Barracuda drag car, 360, auto, and a set of Doug's "D" Dart headers. They are not for the faint of heart, and you don't want to take them off and put them on alot, it gets old real fast, you do not need a special starter, nor do you need a mini starter, clearance is best with a standard starter. They do work well though.
I do not know anything about TTi's other than they are out there.
Cutting the cross member for exhaust pipe clearance is not too hard, but you do need a welder or axcess to one.
Good luck,
Jim Burch
Re: Does anyone make headers for 66 Barracuda [Re: JBurch] #515084
11/04/09 12:05 PM
11/04/09 12:05 PM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
I run 12.56 in the quarter with a stock 360 and spitfires with a t-ram
