833-4 speed & its limitations ????
#514735
11/02/09 10:52 PM
11/02/09 10:52 PM
Posts: 1,340 Pennsylvania
proshiftcharger
Pennsylvania
I know most of you guys are now running Jerricos etc. but...who is currently or has at least run a 833 in the past? At what point is to much HP for a 833 4 speed? How much does the weight of your car play a roll in the 4 speeds limitations? "833-HEMI 4 speed Aluminum box Proshifted by Liberty Mcleod Clutch/pressure plate SFI flywheel" 4 speed guys chime in please. thanks in advance, Doug
Re: 833-4 speed & its limitations ????
[Re: proshiftcharger]
#514738
11/03/09 09:00 PM
11/03/09 09:00 PM
Posts: 8,716 Baltimore/Denver
64Post
Baltimore/Denver
A local guy had that same trans in his '65 680 FWHP Hemi Coronet. He blew a hole in it in short order. Stay with the iron case.
#514739
11/03/09 09:15 PM
11/03/09 09:15 PM
Posts: 10,556 Rittman Ohio
fourgearsavoy
Rittman Ohio
I was OK with an 18 spline box until I put the Mcleod Street-Twin in front of it.I learned quickly that I needed a loose clutch to keep it together.I split a 3-4 slider and broke a third drive gear and cluster.Now the most important thing to consider is weight and traction,if you have both of those then you need a clutch that slips. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: fourgearsavoy]
#514740
11/03/09 09:24 PM
11/03/09 09:24 PM
Posts: 1,169 Virginia Beach, VA
Old School
Virginia Beach, VA
i have an 18 spline in my charger.it weighs 3750lbs with 707 rwhp.it does not hook well,has 275/60 street tires.i think wheelspin saves them.....
68 cuda formula S 588" bb 5sp 70 CUDA CONVERT 500" 5SP (SUBLIME) 70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
#514741
11/03/09 10:46 PM
11/03/09 10:46 PM
Posts: 43,283 Bend,OR USA
Cab_Burge
The correct answer is "it depends on your parts combination, HP and torque and traction". A 18 spline 833 will hold up a lot better to HP and traction than a 23 spline will, as fourgearsavoy has already said, a loose clutch covers up a lot of the weak points in the drivetrain. You have to feed the drivetrain in a four gear car with HP, you can feed it tires, clutches, ring and pinions, U joints, axle and so on, you decide which parts you want to feed the car I ran a 70 Hemi Cuda 4 speed car in NHRA stock for several years in the mid 1970s, I used both Liberty and nash Pro shifted gears in both boxes, it ate the 3-4 slider and 3rd and 4th gears as well as a clutch disc about evry 40 runs Clutch disc where cheap back then, the rest of the parts weren't Good luck
#514742
11/04/09 08:37 AM
11/04/09 08:37 AM
Posts: 5,207 Menomonee Falls
DemonDust
Menomonee Falls
I'd say toss the aluminum case, no strength there
I have a hemi 4 speed with iron case.
I took my car for a severe street beating the other day I took it up to 9600 rpms and shifted it was a little difficult, probably from the RPMS. My engines around 900hp. So I'll let you know when and how it breaks.
[Re: DemonDust]
#514743
11/04/09 12:54 PM
11/04/09 12:54 PM
Posts: 75,083 U.S.S.A.
JohnRR
U.S.S.A.
what are you using for a clutch ?
[Re: DemonDust]
#514746
11/04/09 05:29 PM
11/04/09 05:29 PM
JohnRR
U.S.S.A.
I had a centerforce dual friction from my last engine. So I decided to use it.
that's probably part of your hard shifting issue ...
[Re: JohnRR]
#514747
11/04/09 05:39 PM
11/04/09 05:39 PM
DemonDust
Menomonee Falls
You think it's not disengaging?
[Re: DemonDust]
#514749
11/04/09 09:10 PM
11/04/09 09:10 PM
proshiftcharger
Pennsylvania
Thanks for all your post, I appreciate it. Theres a lot of variables involved and every cars different. One thing I failed to mention was it is for strip use with slicks. Even though no HP/TQ numbers were given in your post its clear theres gonna be problems.... the better your traction and the more HP/TQ. Eventually i will have to upgrade to something else. For now maybe I'll just set the car up to spin a little off the line its all a journey. thanks again, Doug
[Re: SomeCarGuy]
#514750
11/05/09 10:06 AM
11/05/09 10:06 AM
Posts: 9,910 Eighty Four, PA
B G Racing
Eighty Four, PA
I ran the hemi 4 speed(crash box)(slick shifted) behind my C/A,Ultra/Stocker(fuel injected Hemi) for years,only issue was the imput shaft would eat the engagement teeth rather quickly(about every 30-40 runs.I fixed that with a Clutchflite
I thought the ClutchFlite discussion a few months ago mentioned they were on the weak side?
I ran B&M Clutchflites and Fairbanks C/F in my C/A,Ultra/Stocker,A/FX and B/G Dragster.They were great but knowing what I know now I wouildn't get within a 1000 feet of one especially in the B/G dragster(front engine)like having a land mine setting between your legs.
[Re: DemonDust]
#514751
11/05/09 12:32 PM
11/05/09 12:32 PM
JohnRR
U.S.S.A.
at 9600 rpm , probably not completely
