Page 1 of 3 1 2 3
11 seconds with a 416 #514527
11/02/09 07:37 PM
11/02/09 07:37 PM
clarks summit pa
73cuda340 Offline OP
clarks summit pa
Any thoughts on how to build a 416 to hit 11's in a street car? Im planning on building one soon and was wondering if my combo would hit 11s or not. Going into a 73 cuda.
1973 Cuda 528 all aluminum Hemi, 4 speed, 3.23 Sure-Grip, (JA5) Silver Frost Metallic 1973 Challenger Rallye 340 1985 W150 Power Ram prospector 1986 Camaro IROC-Z 305 tpi
Re: 11 seconds with a 416 [Re: 73cuda340] #514528
11/02/09 08:15 PM
11/02/09 08:15 PM
south louisiana
lowell66dart Offline
south louisiana
Depends on if your willing to run some gear and a stall converter. Then your going to need the right cam, compression etc. Really need to define what street means to you. Pick one of the builders that answer many questions here in the race section and you can't go wrong.
Ok now I see the four speed info. That makes thinks somewhat easier, except for traction maybe.
2021 Dodge 2500 4WD Cummins
2020 Challenger R/T Scat Widebody
2007 Charger R/T 5.7
Re: 11 seconds with a 416 [Re: lowell66dart] #514529
11/02/09 10:03 PM
11/02/09 10:03 PM
acworth / N. georgia - south e...
cheapstreetdustr Offline
i am seeing them run ten-30-40's in race car trim.
i dont see why 11's in street trim wouldnt be more than possible.
cheapst.
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured
[image][/image]
Re: 11 seconds with a 416 [Re: cheapstreetdustr] #514530
11/02/09 10:07 PM
11/02/09 10:07 PM
Northeast, Alpine, NY
9
9 Sec Phill Offline
On a road near you
9 Sec Phill  Offline
On a road near you
9
My old cuda ran 10.90s with a 416 on pump gas. Street car all the way, drive it for hours if needed. 3.91 gear....Phill
Re: 11 seconds with a 416 [Re: 9 Sec Phill] #514531
11/02/09 10:45 PM
11/02/09 10:45 PM
Joplin, Mo
rt66jim Offline
rt66jim  Offline
Joplin, Mo
LAR414 has one as well. Mid 11's will be no problem at all with the right parts. Jim
Re: 11 seconds with a 416 [Re: lowell66dart] #514532
11/02/09 10:49 PM
11/02/09 10:49 PM
clarks summit pa
clarks summit pa
. Really need to define what street means to you. Ok now I see the four speed info. That makes thinks somewhat easier, except for traction maybe.
To me street means that the car is not all gutted for weight reduction, no slicks (although drag radials are acceptable). Im not in anyway considering running freeway gears, but at the same time nothing like 4.56s or anything that is too low for the street.
Re: 11 seconds with a 416 [Re: rt66jim] #514533
11/02/09 10:49 PM
11/02/09 10:49 PM
Maryland
340_Dart Offline
340_Dart  Offline
Maryland
I've already told you the combo in my dart previously... Street car all the way... 11.24 @ 119 mph on Drag radials and thru the mufflers... 3350lbs race weight
Re: 11 seconds with a 416 [Re: 340_Dart] #514534
11/02/09 10:52 PM
11/02/09 10:52 PM
clarks summit pa
clarks summit pa
Thanks, I remember you combo and appreciate your post. Im just looking to get others builds as well.
Re: 11 seconds with a 416 [Re: 73cuda340] #514535
11/02/09 11:03 PM
11/02/09 11:03 PM
Joplin, Mo
rt66jim Offline
rt66jim  Offline
Joplin, Mo
My 69 Dart weighed 3500. It was tagged and insured. My times were on 9" slicks. 11.08 @ 120 mph. 11 teens and twenties in the heat were no problem. Ran a 4.30 gear with a 29.5" street tire. I could cruise 55 to 60 mph at 3200 rpms. I wouldn't want to take it vacation but for short cruises it was OK. Jim http://www.cxpressphotography.com/asccus...avParent=121400
Re: 11 seconds with a 416 [Re: 73cuda340] #514536
11/03/09 01:35 AM
11/03/09 01:35 AM
Sunnyvale, CA
Jeepmon Offline
Jeepmon  Offline
Sunnyvale, CA
I have a pump gas 410 cid in a completely stock, full trim, all steel 73 Duster and its ran a best of 11.2x @ 118..
My combo is..
4" cast stroker crank
HV oil pump
Kevko oil pan
Callie main and rod bearings with that friction reducing stuff..
KB forged step pistons 22.5 CC
Scat H-beams
Eddy heads ported by Ryan.. also shaved to obtain a chamber volume of 57cc.. which makes compression ratio 10.9:1
Heads flow about 280-ish cfm intake and 235-ish exhaust
Custom Ground Comp Cam 256/262 @ .050" Duration
108 LSA
.635"/.632" With Crane gold 1.5 roller rockers
Comp roller lifters
MSD billet dist.
MSD Digital 6 ignition box
Super Victor port matched (the intake was also shaved to line up with the shaved Eddys)
Holley 750
544 tq was obtained @4400 rpm
528 hp was @ 6000
Re: 11 seconds with a 416 [Re: Jeepmon] #514537
11/03/09 01:47 AM
11/03/09 01:47 AM
Poulsbo, WA
ChrisJohnston669 Offline
Poulsbo, WA
I sure hope it goes 11s. My buddy has a 416 with ootb eddys and a smaller solid cam and has run 10.42 in a 71 dart.
Re: 11 seconds with a 416 [Re: ChrisJohnston669] #514538
11/03/09 04:57 AM
11/03/09 04:57 AM
Sure can be done my "street" duster,with full interior,6-point roll bar,full exhaust ran consistent 11.0's with my hyd. cammed 416..
Re: 11 seconds with a 416 #514539
11/03/09 06:32 AM
11/03/09 06:32 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
I ran a '65 Dart all summer with a very mild 416 on pump gas. Went 11.70 in the 1/4 but 7.37 in the 1/8th. Don't choke it off with crappy heads like we did. Ours were stock unported 360 heads with chevy valves, and it just lays down after the 1/8th mile. Changing them out for next year. Car was 9.5:1 compression on pump fully tagged and street driven. We run slicks for the track, but it 60ft hard enough it needs them. Car is just nasty fast till the 1/8th and should run low 11's early next season. The 416 is a torque monster that doesn't need a ton of gear to go really well.
Re: 11 seconds with a 416 [Re: Dragula] #514540
11/03/09 09:29 AM
11/03/09 09:29 AM
Indy
FlyFish Offline
FlyFish  Offline
Indy
No problem with a stroker. I drive my Cuda on the street...totally street able package (for me anyway). Even drive the wife and kids around with it.
360, Eagle 4 inch steel crank, Diamond pistons, Scat I-beams, ported eddy heads (Thanks RyanJ), air-gap, proform 750 dp, small solid roller cam, 8" converter, 4.10 gear, 10.8:1 compression on pump gas.
Still tuning, current best in sig, but I KNOW I will get this thing into the 10's next year (after swapping the intake and carb for a Victor and a 950).
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
Re: 11 seconds with a 416 [Re: ChrisJohnston669] #514541
11/03/09 01:21 PM
11/03/09 01:21 PM
Sunnyvale, CA
Jeepmon Offline
Jeepmon  Offline
Sunnyvale, CA
I agree.. there is soemthing wrong with my combo, I think I should easily be in the 10's.. but thats for another post at another time..
In my defense, I still have air shocks and the wrong offset wheels which causes tire rub.. So before I can get serious cutting down the ET, I'll need to get better weight transfer.. until then, its a street car that I enjoy in this beautiful Calif weather..
Re: 11 seconds with a 416 [Re: Jeepmon] #514542
11/03/09 01:25 PM
11/03/09 01:25 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
72cuda416 runs 11.3 with an eddy headed setup in full street trim.......
Mopar Performance
Re: 11 seconds with a 416 [Re: 73cuda340] #514543
11/03/09 01:43 PM
11/03/09 01:43 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I went 11.80`s years ago w/a iron headed 360+.030 daily driver and it definately was nothing special. Stock heads w/mild clean up solid isky cam, good valve job,10" vert, 3.91`s and loaded my drums up and drove everywhere for gigs up to 100 miles at times so today it should be a breeze as others have stated especially at 416 cubes.
Re: 11 seconds with a 416 [Re: Thumperdart] #514544
11/03/09 01:55 PM
11/03/09 01:55 PM
...gently down the stream
LAR_414 Offline
LAR_414  Offline
I've never been in the 12's with my stroker, since I built it like 7 years ago, at least never on a full run. The first time down the track was 11.85 and ran 11.07 last year with the automatic trans. First run with the stick and ran a 11.9 missing 3 gears and blowing the tires off.
Mine is very much a street car. No need to restate what I do with my car, and where I go with it.
These 4" arms are FUN!!!!
Re: 11 seconds with a 416 [Re: LAR_414] #514545
11/06/09 06:34 PM
11/06/09 06:34 PM
clarks summit pa
clarks summit pa
Can anyone guess what my combo will run?
73 cuda
416
ported 2.02 J heads
Edelbrock air gap with 750 double pumper, or LD340 with thermoquad (have both)
cam somewhere in the 240@50 range
10:1 compression
4 speed
3.23 sure-grip
Re: 11 seconds with a 416 [Re: 73cuda340] #514546
11/06/09 06:38 PM
11/06/09 06:38 PM
Joplin, Mo
rt66jim Offline
rt66jim  Offline
Joplin, Mo
James(TheOtherDodge) had one several years ago that ran 11.4's or 11.3"s as I recall. Perhaps he will see this and post. Jim
Page 1 of 3 1 2 3
