11 seconds with a 416
#514527
11/02/09 07:37 PM
11/02/09 07:37 PM
Posts: 1,179 clarks summit pa
73cuda340
clarks summit pa
Any thoughts on how to build a 416 to hit 11's in a street car? Im planning on building one soon and was wondering if my combo would hit 11s or not. Going into a 73 cuda.
1973 Cuda 528 all aluminum Hemi, 4 speed, 3.23 Sure-Grip,
(JA5) Silver Frost Metallic
1973 Challenger Rallye 340
1985 W150 Power Ram prospector
1986 Camaro IROC-Z 305 tpi
Re: 11 seconds with a 416
[Re: 73cuda340]
#514528
11/02/09 08:15 PM
11/02/09 08:15 PM
Posts: 885 south louisiana
lowell66dart
south louisiana
Depends on if your willing to run some gear and a stall converter. Then your going to need the right cam, compression etc. Really need to define what street means to you. Pick one of the builders that answer many questions here in the race section and you can't go wrong. Ok now I see the four speed info. That makes thinks somewhat easier, except for traction maybe.
2021 Dodge 2500 4WD Cummins 2020 Challenger R/T Scat Widebody 2007 Charger R/T 5.7
[Re: lowell66dart]
#514529
11/02/09 10:03 PM
11/02/09 10:03 PM
Posts: 6,257 acworth / N. georgia - south e...
cheapstreetdustr
i am seeing them run ten-30-40's in race car trim. i dont see why 11's in street trim wouldnt be more than possible. cheapst.
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured [image][/image]
[Re: ChrisJohnston669]
#514538
11/03/09 04:57 AM
11/03/09 04:57 AM
Sure can be done my "street" duster,with full interior,6-point roll bar,full exhaust ran consistent 11.0's with my hyd. cammed 416..
[Re: Dragula]
#514540
11/03/09 09:29 AM
11/03/09 09:29 AM
Posts: 1,178 Indy
FlyFish
Indy
No problem with a stroker. I drive my Cuda on the street...totally street able package (for me anyway). Even drive the wife and kids around with it.
360, Eagle 4 inch steel crank, Diamond pistons, Scat I-beams, ported eddy heads (Thanks RyanJ), air-gap, proform 750 dp, small solid roller cam, 8" converter, 4.10 gear, 10.8:1 compression on pump gas.
Still tuning, current best in sig, but I KNOW I will get this thing into the 10's next year (after swapping the intake and carb for a Victor and a 950).
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
#514541
11/03/09 01:21 PM
11/03/09 01:21 PM
Posts: 8,094 Sunnyvale, CA
Jeepmon
Sunnyvale, CA
I sure hope it goes 11s. My buddy has a 416 with ootb eddys and a smaller solid cam and has run 10.42 in a 71 dart.
I agree.. there is soemthing wrong with my combo, I think I should easily be in the 10's.. but thats for another post at another time..
In my defense, I still have air shocks and the wrong offset wheels which causes tire rub.. So before I can get serious cutting down the ET, I'll need to get better weight transfer.. until then, its a street car that I enjoy in this beautiful Calif weather..
[Re: LAR_414]
#514545
11/06/09 06:34 PM
11/06/09 06:34 PM
73cuda340
clarks summit pa
Can anyone guess what my combo will run? 73 cuda 416 ported 2.02 J heads Edelbrock air gap with 750 double pumper, or LD340 with thermoquad (have both) cam somewhere in the 240@50 range 10:1 compression 4 speed 3.23 sure-grip
