JETTING FOR CARTER AVS *DELETED* *DELETED* #514190
11/02/09 12:53 PM
11/02/09 12:53 PM
PENNSYLVANIA
CERTIFIABLE_HEMI Offline OP
PENNSYLVANIA
Post deleted by CERTIFIABLE_HEMI
Re: JETTING FOR CARTER AVS [Re: CERTIFIABLE_HEMI] #514191
11/02/09 02:22 PM
11/02/09 02:22 PM
tn
r69cuda Offline
r69cuda  Offline
tn
rod #16-546 pri jet 120-489 sec jet 120-422
Re: JETTING FOR CARTER AVS [Re: r69cuda] #514192
11/02/09 04:46 PM
11/02/09 04:46 PM
PENNSYLVANIA
PENNSYLVANIA
Thanks, I appreciate the info.
Re: JETTING FOR CARTER AVS [Re: CERTIFIABLE_HEMI] #514193
11/02/09 04:58 PM
11/02/09 04:58 PM
fyi eddie 2 step rods/jets/springs will work in an oe AVS plus epoxy the metering rod caps full to make them flat like the AFB/eddie ones and as I'm sure you know oe AVS 3 step strip kits are pretty much non existant and since all oe AVS's were emission calibrated carbs which can benefit from rejetting.
