Page 3 of 3 1 2 3
Re: WASTED MOTOR TODAY....not pretty.,,,,,,,, [Re: JoesMopar] #513368
11/02/09 09:38 AM
11/02/09 09:38 AM
ky
68roadrunner Offline
ky
hi doug, sorry about the engine. i did one like that this year, it really blows.
i saw that run, i was going to try to meet you, but you left before i got a chance. another day.
get to ording parts.
Re: WASTED MOTOR TODAY....not pretty.,,,,,,,, [Re: JoesMopar] #513369
11/02/09 09:45 AM
11/02/09 09:45 AM
GO BUCKS !!!!!!!
3
340RICK Offline
340RICK  Offline
GO BUCKS !!!!!!!
That sucks Doug. At least you have all winter to build the new motor.
Re: WASTED MOTOR TODAY....not pretty.,,,,,,,, [Re: 340RICK] #513370
11/02/09 10:25 AM
11/02/09 10:25 AM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
Wow Doug, sorry to hear about this. As many others have said at least the damage was contained in the motor and you didn't get oil under the car at speed.
Re: WASTED MOTOR TODAY....not pretty.,,,,,,,, [Re: Bigcube] #513371
11/02/09 10:38 AM
11/02/09 10:38 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Well that sucks!
Re: WASTED MOTOR TODAY....not pretty.,,,,,,,, [Re: 69CHARGERMD] #513372
11/02/09 12:25 PM
11/02/09 12:25 PM
Indiana
W5Duster436 Offline
W5Duster436  Offline
Indiana
Sorry to hear the bad news.
Holler if you need any help tearing it down etc.
'70 Duster - SDSS 436 W5 4spd (Gone)
'71 Dodge D100
'70 Dodge W100
Re: WASTED MOTOR TODAY....not pretty.,,,,,,,, [Re: W5Duster436] #513373
11/02/09 12:57 PM
11/02/09 12:57 PM
off the grid
340B5 Offline
340B5  Offline
off the grid
Definately puts the UG in ugly. Ouch.
Yeah, it's got a smallblock.
Re: WASTED MOTOR TODAY....not pretty.,,,,,,,, [Re: 69CHARGERMD] #513374
11/02/09 05:26 PM
11/02/09 05:26 PM
Central Missouri - USA
Ramcharger Offline
super gas
Ramcharger  Offline
super gas
Ooopps! I guess that answers the question of how long that old engine will last. There is no telling how many hundreds of passes were on those rotating parts. Bobby had 5 hard years on them before Doug bought the car. I would take a very conservative guess and say Bobby had well over 500 passes on it before Doug took over.
The rods were Eagle. Stock 440 steel crank. Stock 440 block with ARP main studs. No main girdle unless Doug added one a couple of years ago when he freshened the engine. Also, no concrete or filler when we originally built the engine.
I don't mean to jinx it, but I'd bet that there is some major destruction when it is all said and done. I'm really surprised that it didn't window the block. I'm really curious to see how the main webs held up as well.
Hey Doug! If you would be willing to get rid of any scrap pieces that you don't want or can't use, I'll take them off your hands. I like showing my Auto Tech students what happens when things come apart.
'64 Dodge 440 2 dr. sedan - 440/pushbutton 727 (in the body shop)
'99 Dodge 2500 Quad Cab Long bed 4WD - CTD 5 spd. 3.54
'89 Dodge 150 4x4 - 5.9 TBI/727 35x12.50's and 8" lift
'14 Dodge Dart Limited 2.4/6-speed A/T
Re: WASTED MOTOR TODAY....not pretty.,,,,,,,, [Re: Ramcharger] #513375
11/02/09 05:32 PM
11/02/09 05:32 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Dang Doug that sucks...
On a lighter note, atleast it happened at the End of the season, and gives you a winter project..
So whats your plans for a new Bullet?
Re: WASTED MOTOR TODAY....not pretty.,,,,,,,, [Re: Ramcharger] #513376
11/02/09 07:30 PM
11/02/09 07:30 PM
KENTUCKY
69CHARGERMD Offline OP
KENTUCKY
I am pretty sure i put about 50-75 runs after i bought the car from Bobby,,before i went thru the motor,,and about another 300 plus passes after the motor was redone in 2006 until now ,and got the car to run 10.26 @ 130MPH with a 1.40-1.41 60',,,
I had the motor re-done in 12/2006,,ie clean block, magnaflux, hone, new cam bearings, freeze plugs, line hone, rings, bearings, oil pump, gaskets, crank polish, new cam, lifters, and had the E heads ported, and bumped the compression up to 13:1 The pistons, block and rods were re-used
I don't mean to jinx it, but I'd bet that there is some major destruction when it is all said and done. I'm really surprised that it didn't window the block. I'm really curious to see how the main webs held up as well. I was lucky,,,NO leaks,,nothing,,,i thought i broke the rear end,,,not the motor,,
Hey Doug! If you would be willing to get rid of any scrap pieces that you don't want or can't use, I'll take them off your hands. I like showing my Auto Tech students what happens when things come apart. I'll let ya know,,,,you might have to make a road trip to Louisville, overall it's been a really good motor for what it is/was,,440 .030, foot brake,,etc
Re: WASTED MOTOR TODAY....not pretty.,,,,,,,, [Re: 69CHARGERMD] #513377
11/02/09 08:03 PM
11/02/09 08:03 PM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
sorry to hear and see Doug...
Re: WASTED MOTOR TODAY....not pretty.,,,,,,,, [Re: 69CHARGERMD] #513378
11/02/09 08:20 PM
11/02/09 08:20 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
You done blowed it up REAL good!
Just glad to hear you're ok and the rest of the car is unhurt.
Re: WASTED MOTOR TODAY....not pretty.,,,,,,,, [Re: ZIPPY] #513379
11/02/09 08:50 PM
11/02/09 08:50 PM
TN
65racer Offline
2009 IHRA World Champion
65racer  Offline
TN
Doug,
Man, that's tough, looks like a rod bolt let go, turned the cap loose, and did the damage to the inside of the block, if the rod cap had stayed hooked to the rod, it would have for sure took out the side of the block.
Hate that it had to happen, but things like this
are going to take place, sooner or later, with the damands we put on these engines.
Re: WASTED MOTOR TODAY....not pretty.,,,,,,,, [Re: 69CHARGERMD] #513380
11/04/09 11:53 AM
11/04/09 11:53 AM
NC
440Jim Offline
440Jim  Offline
NC
I am pretty sure i put about 50-75 runs after i bought the car from Bobby,,before i went thru the motor,...,and about another 300 plus passes after the motor was redone in 2006 until now ...
Sorry to see the destruction. Close to 900 race passes on a factory crank is a lot. Interesting that it magnaflux checked with no hairline cracks at the 2006 rebuild (~575 runs).
Still it seems rod related (bolt, bearing, etc).
Re: WASTED MOTOR TODAY....not pretty.,,,,,,,, [Re: JoesMopar] #513381
11/08/09 11:55 AM
11/08/09 11:55 AM
Watertown, WI
MikeyT Offline
MikeyT  Offline
Watertown, WI
ouch! sorry to see that Doug! Winter is upon us so hopefully you can get it fixed before the spring.
Mike
1969 Dodge Dart Swinger
Re: WASTED MOTOR TODAY....not pretty.,,,,,,,, #513382
11/11/09 12:47 AM
11/11/09 12:47 AM
Central Queensland Australia G...
D/U R/T Offline
D/U R/T  Offline
Doug, just built a killer 500 motor with mega block, 440-1's, you can have it cheap. 722 hp, if you need one.
Hey you want to send that motor on an all expenses paid holiday to Australia.722 would be awesome.Might need to lend a gearbox and a diff.
Re: WASTED MOTOR TODAY....not pretty.,,,,,,,, [Re: D/U R/T] #513383
11/11/09 06:43 AM
11/11/09 06:43 AM
KENTUCKY
KENTUCKY
Page 3 of 3 1 2 3
