Re: Too much gear
[Re: Not a bee]
#513259
11/01/09 05:06 PM
11/01/09 05:06 PM
you might be a tad high, but you need that gear because your car is heavy. you could go to a 29.5 tire, which would drop you down a little trough the traps. your stuck in a catch 22 situation. i wouldnt change the gears.
Re: Too much gear
#513261
11/01/09 05:22 PM
11/01/09 05:22 PM
Posts: 1,880 USA
Ron Silva
USA
I would definately go to a taller rear tire. It's easy enough to do.
Get out in front of the house and burn off what you have and then order a new set of tires.
Some say you want to be 10% past peak power in the traps.
SRT DEMON ONE SEAT
Re: Too much gear
[Re: Ron Silva]
#513263
11/01/09 05:40 PM
11/01/09 05:40 PM
Posts: 1,596 BX, CT, FL.
B1KILLER
BX, CT, FL.
Re: Too much gear
[Re: tjmarcus1]
#513265
11/01/09 05:55 PM
11/01/09 05:55 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
Let me be the first to say
Post all the details of your set up. There are some truly knowledgable folks here that can let you know if somethings not matched for optimum performance or if your leaving something on the table.
And no,
I'm not one them
Re: Too much gear
[Re: tjmarcus1]
#513266
11/01/09 05:57 PM
11/01/09 05:57 PM
Posts: 26 Northern MN
Not a bee
Northern MN
with it peaking at 5500, i'm guessing it has a hyd. cam? if it has, it probably has stopped making power at that rpm.
Solid flat tappet. .550/.570. I can't remember exactly the at .50 I think .250/.260.
Re: Too much gear
[Re: Not a bee]
#513267
11/01/09 07:04 PM
11/01/09 07:04 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
I am close to your combo in my 63. It weighs just over 3700 with me in the car and it is a .030 over 440 (446) with KB pistons and stock bottom end. I use 906 heads and the MP .557 cam. Holley Street Dominator intake and 850 DP. I run 4.30's with a 30" tire. I shift about 6200 and trap about 6400. Dynamic 9.5 converter flashes about 4200 and a best et of 11.52 @ 116. Best sixty is a 1.57. I feel I may go faster with a bit less gear as I am pretty well wound out going thru the traps. But if you have 4.10's and a 28" tire I would not go to less gear. As for the Performer RPM it is a good intake. My son runs one on the 400 in his Dart and shifts about 6700. He has run 11.40's with the same basic combo as me but he has Eddy heads and he uses 3.91's with a 26" tire. I would think maybe more converter in your car rather then a gear change. Ron
Re: Too much gear
[Re: Not a bee]
#513268
11/01/09 07:34 PM
11/01/09 07:34 PM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
How about the intake. Its got a performer rpm. maybe a victor.
Well a victor is going to raise your peak HP RPM up a bunch and I like to be past peak so your using it all. that is the change I would consider!.
Re: Too much gear
[Re: Not a bee]
#513270
11/02/09 02:46 AM
11/02/09 02:46 AM
Posts: 43,157 Bend,OR USA
Cab_Burge
What RPM are you shifting at in 1st and 2nd gear? If 5500 RPM or close to that try moving the shift points up to 5800 or 6000 RPM and see what that does before you change anything else. My Duster motor makes peak power on the engine dyno(two different tests on two different dynos two years apart) at 5600 RPM on the first tests with iron heads and 5800 RPM on the second tests with CNC ported Eddy RPM heads, the car runs faster shifing it at or above 7000 RPM in 1st and 2nd gear The first cuople of times I raced it I shifted it at 5400 rpm and 5600 RPM, it seemed like it spent a long time in high gear I switch tachs to a VDO Extreme playback and treid shifting a little higher, two to three hundred RPM each time. The tach never slows down on the play back, even shifting at 7500 RPM, where I get scared and move the lever anyways. The higher I shift it the faster it goes, that is with a Eddy six pak intake and stock type Holley carbs. I have treid 3:73, 3:91 and 4;10 in the car and it goes 128.6 with all three ratios some things don't make sense but they work anyways
