The hot rod EXPLODED today #505
06/02/03 09:42 PM
06/02/03 09:42 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
I was pulling out of work and merging with traffic when the whole car exploded!
I slapped the kill switches and pointed it towards where I thought the curb would be. The smoke was so thick that I couldn't see the steering wheel much less anything else!
The guys at work saw it from 100 yards away and totally freaked.
My first thought was that the battery in the trunk exploded. The second thought was that all my work for the Power Tour was wasted.
I got the car stopped and got out. That's when I tasted it. The smoke. It's not smoke. It's powder.
My friggin 10 pound dry powder fire extinguisher blew. It's been behind the driver's seat for two years and picked today to blow it's top.
Scared the ever-lovin blue-eyed chit outta me.
I've got yellow/white powder all over the inside and outside of the car. I doubt my shop vac will ever be able to get all that crap outta there.
I'm picking up a new extinguisher tomorrow. I don't like the idea of not having one in the car.
- Stu Harmon
Re: The hot rod EXPLODED today [Re: feets] #506
06/02/03 09:49 PM
06/02/03 09:49 PM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
CO2 or halon is the ONLY way to go...no crap to ingest in the motor if its ever called for - get that powder outta there, I hear it can be pretty corrosive if left to sit...
Re: The hot rod EXPLODED today [Re: feets] #507
06/02/03 09:49 PM
06/02/03 09:49 PM
Sorry to hear that, but its much better than your car buring to the ground!
Re: The hot rod EXPLODED today [Re: feets] #508
06/02/03 09:49 PM
06/02/03 09:49 PM
Detroit Michigan
drbill Offline
drbill  Offline
Detroit Michigan
Sorry about the explosion and mess you have to clean up but that is pretty darn funny.
Re: The hot rod EXPLODED today [Re: feets] #509
06/02/03 09:52 PM
06/02/03 09:52 PM
Sorry to hear about the mess, but count your blessings...It coulda been far worse.
Are you still planning on the Power Tour? I'm jealous..My car is nowhere near ready. Oh well, maybe next year.
Re: The hot rod EXPLODED today #510
06/02/03 09:55 PM
06/02/03 09:55 PM
This post scared me about as much as your accident scared you.. I LOVE your car and I was expecting the worst when I saw this
Re: The hot rod EXPLODED today #511
06/02/03 09:59 PM
06/02/03 09:59 PM
This thread scared the fsck out of me! Glad to hear you and your ride is ok, though.
Re: The hot rod EXPLODED today #512
06/02/03 10:05 PM
06/02/03 10:05 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Glad it wasn't anything too serious.
PS: I HOPE THAT YOU CHANGED YOUR SHORTS!!!!!!!!!!!!!!!
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Re: The hot rod EXPLODED today [Re: feets] #513
06/02/03 10:13 PM
06/02/03 10:13 PM
VA
E
Ed_Devinney Offline
super gas
Ed_Devinney  Offline
super gas
E
VA
Shazam! Glad to hear everything is still together, although with a new color scheme. And yes, as far si I know, it's corrosive.
I'll second the vote for halon. Expensive, but cheaper than rebuilding the engine after you fire it off under the hood. Reminds me I need to get one for my hot rod, have one in the road course car, but still have dry chemical in the 'cuda...
Re: The hot rod EXPLODED today [Re: MoparforLife] #514
06/02/03 10:13 PM
06/02/03 10:13 PM
N
NITROUSN Online content
NITROUSN  Online Content
N
i saw that happen to a friend competing in a 4 wd. truck race. he was strapped in with his helmet on waiting to be called up when he accidently pushed on the extinguisher. it was supposed to be safety pinned. anyway the cab fills up with yellowish smoke the door opens and he falls out. by the time he realized something was wrong he injested some of the crap and almost passed out. not a good experience. feets you were lucky it happened in a area where you could get off the road. could of been a lot worse.
Re: The hot rod EXPLODED today [Re: Ed_Devinney] #515
06/02/03 10:16 PM
06/02/03 10:16 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
I'm a bit hesitant to run halon due to some mental delusion of it displacing oxygen. I'm worried about inhalation and the fact that it's much heavier than breathable air.
The powder is a mess but I don't ever plan on poking it down the carb throat. I've got stuff inside the car to smother that if necessary.
- Stu Harmon
Re: The hot rod EXPLODED today [Re: feets] #516
06/02/03 10:28 PM
06/02/03 10:28 PM
VA
E
Ed_Devinney Offline
super gas
Ed_Devinney  Offline
super gas
E
VA
Halon and CO2 both displace air, but they're really only dangerous in closed spaces like rooms with big fixed extinguisher systems. There is some risk to inhaling the halon itself, more so from inhaling the products it releases when in a fire, but in a car situation with lots of fresh air that's not a big deal. I guess if you use it on a fire inside the car with the windows up you might have a problem, but the halon would be the least of my problems there :-0
erd.dli.state.mt.us/Safety/SB_brochures/HALON.pdf
Re: The hot rod EXPLODED today [Re: Ed_Devinney] #517
06/02/03 10:35 PM
06/02/03 10:35 PM
an8sec70cuda Offline
when i first saw this, my first thought was the fuel system or something glad to hear everything is ok!! CHIP
CHIP
'06 GMC 2500HD LBZ Duramax
Re: The hot rod EXPLODED today [Re: an8sec70cuda] #518
06/02/03 10:59 PM
06/02/03 10:59 PM
los angeles ca.
70rtdroptop Offline
super gas
70rtdroptop  Offline
super gas
los angeles ca.
wow. think i will have mine checked and put it in trunk.man i thought you blew up the motor or trans, you were lucky it happend totady
70 rt / 500 built my way 440 dana 60 disc brakes auto air power roof tons of fun and lots of style
Re: The hot rod EXPLODED today [Re: feets] #519
06/02/03 11:17 PM
06/02/03 11:17 PM
Tomorrow.
Damned67 Offline
Damned67  Offline
Tomorrow.
Glad that was all the drama. Like many, the "hot rod" is one of my fave car's on the board.
And what exactly is
Re: The hot rod EXPLODED today [Re: Damned67] #520
06/02/03 11:25 PM
06/02/03 11:25 PM
Sorry to hear about your "explosion". I am glad to hear you were able to pull over safely. How hot was it today? Was the heat a possible reason for the explosion? Sorry that I don't have any suggestions for cleaning up the mess. Better luck in the future.
Re: The hot rod EXPLODED today [Re: Damned67] #521
06/02/03 11:29 PM
06/02/03 11:29 PM
"the ever-lovin blue-eyed chit" is the stuff in the shorts he changed.
Re: The hot rod EXPLODED today #522
06/02/03 11:31 PM
06/02/03 11:31 PM
Wisconsin
beeper71 Offline
moparts member
beeper71  Offline
moparts member
Wisconsin
Holy crap! You had me scared there for a minute!
Glad thats "all" it was though!GEEZ!
Sounds like you have a big azz mess to clean up.
Re: The hot rod EXPLODED today [Re: feets] #523
06/03/03 12:31 AM
06/03/03 12:31 AM
Edmonton, Alberta, Canada
Dartman75 Offline
Dartman75  Offline
Glad to hear it wasn't the powertrain that blew up. Time to take advantage of a car cleaners with flat rates! Use CO2, unless you plan on using it in an enclosed area for longer than you could hold your breath...
Greg
Re: The hot rod EXPLODED today [Re: feets] #524
06/03/03 02:40 AM
06/03/03 02:40 AM
Arlington, Texas
earlybee Offline
earlybee  Offline
Arlington, Texas
man i,m glad your alright! did it look like your sig pic except on the inside!! yea your post heading got me too!!
