exploded 8 1/4 SureGrip view? #512743
10/31/09 09:54 PM
10/31/09 09:54 PM
Indiana
MonGoo$e Offline OP
MonGoo$e  Offline OP
Indiana
Anyone here have an exploded view of an 8 1/4 SureGrip? I saw the 8 3/4 in the tech archives so no luck there.
I picked up an 8 1/4 SG and I had a lot of rust to clean out of it. Spiders have some pitting and I'm curious if there are supposed to be thrust plates behind the 2 larger ones?
Any help is appreciated.
My YouTube Channel, "Hoosier Garage"
https://www.youtube.com/HoosierGarage
Re: exploded 8 1/4 SureGrip view? [Re: MonGoo$e] #512744
10/31/09 11:29 PM
10/31/09 11:29 PM
connecticut
pnypwr Offline
pnypwr  Offline
connecticut
is it a clutch type? grip or a cone type?
"Are you gonna bark all day lil doggy? Or are you gonna bite?"
05 ram 2500 ctd
74 gremlin x 360
65 mustang 347
70 coronet R/T 440
03 Mach 1
Re: exploded 8 1/4 SureGrip view? [Re: pnypwr] #512745
10/31/09 11:44 PM
10/31/09 11:44 PM
Indiana
MonGoo$e Offline OP
MonGoo$e  Offline OP
Indiana
I'm not real taught on this stuff but I'm guessing Clutch, break the carrier in half and I have the 4 spiders, 2 plates on the faces of the bigger gears and the 5 springs between the plates.
Re: exploded 8 1/4 SureGrip view? [Re: MonGoo$e] #512746
11/01/09 11:45 AM
11/01/09 11:45 AM
Indiana
MonGoo$e Offline OP
MonGoo$e  Offline OP
Indiana
Seems Moparts isn't the place for 8 1/4's
Re: exploded 8 1/4 SureGrip view? [Re: MonGoo$e] #512747
11/01/09 11:51 AM
11/01/09 11:51 AM
St. John's Newfoundland
440newport Offline
440newport  Offline
I can't really help you with yours, but it must be a clutch type because the cone types only have 2 spiders.
It's pretty unlikely that someone had it apart already, and would put plates on 2 of the spiders and not the others, but who knows I guess.
Edit: you say it has 5 spings in between? That sounds like a cone to me. It's been awhile since I had one apart, but I remember the spiders gears having thin cupped washers behind them. But the cones and side gears meshed together with no extra parts.
Re: exploded 8 1/4 SureGrip view? [Re: MonGoo$e] #512748
11/01/09 12:43 PM
11/01/09 12:43 PM
3
340dart4spd Offline
Parts Problem
340dart4spd  Offline
Parts Problem
3
I can help..here yea go
Re: exploded 8 1/4 SureGrip view? [Re: 340dart4spd ] #512749
11/01/09 02:09 PM
11/01/09 02:09 PM
Indiana
MonGoo$e Offline OP
MonGoo$e  Offline OP
Indiana
70 Coronet, thanks but that is an open exploded view.
I talked to a former board member, he said there should ne any washers behind the large spiders because the preload wouldn't allow them to set right, the small ones have them though. I guess I'm fine.
Re: exploded 8 1/4 SureGrip view? [Re: MonGoo$e] #512750
11/01/09 05:56 PM
11/01/09 05:56 PM
md
mopars4ever Online content
mopars4ever  Online Content
md
You have the cone type sure grip. They wear out over time. Unless your real tight on money I would spring for the clutch type. The original cone type sure grips are just marginally good when new.
Re: exploded 8 1/4 SureGrip view? [Re: mopars4ever] #512751
11/01/09 06:00 PM
11/01/09 06:00 PM
3
340dart4spd Offline
Parts Problem
340dart4spd  Offline
Parts Problem
3
you are right..been there done that... they can be machined and shimmed but like you said not the best option....
Re: exploded 8 1/4 SureGrip view? [Re: 340dart4spd ] #512752
11/01/09 06:12 PM
11/01/09 06:12 PM
md
md
Here is one on ebay but I think they are for the 2.45 ratio only but not 100% positive because the part number is not a Mopar one from what I can tell. http://cgi.ebay.com/ebaymotors/ws/eBayIS...AAQ:MOTORS:1123
Re: exploded 8 1/4 SureGrip view? [Re: mopars4ever] #512753
11/01/09 06:29 PM
11/01/09 06:29 PM
Indiana
MonGoo$e Offline OP
MonGoo$e  Offline OP
Indiana
that one on ebay looks exactly like the one I have..even the springs are corporate blue.
Re: exploded 8 1/4 SureGrip view? [Re: MonGoo$e] #512754
11/01/09 06:42 PM
11/01/09 06:42 PM
McGregor,Iowa 52157
500ciDuster Offline
500ciDuster  Offline
McGregor,Iowa 52157
those 2.45 carriers only worked for that gear ratio as I recall
Re: exploded 8 1/4 SureGrip view? [Re: 500ciDuster] #512755
11/01/09 06:54 PM
11/01/09 06:54 PM
Indiana
MonGoo$e Offline OP
MonGoo$e  Offline OP
Indiana
the carrier I pulled from the housing was a 2.71, open ofcourse, and the 3.55 gear I have won't even fit on it(I was just testing it. I've got another open carrier it would fit, and the SG I have it fits fine and also in the housing. okay.
Re: exploded 8 1/4 SureGrip view? [Re: MonGoo$e] #512756
11/01/09 08:07 PM
11/01/09 08:07 PM
Indiana
MonGoo$e Offline OP
MonGoo$e  Offline OP
Indiana
maybe if I posted pics it'd help, I'm always up for learning something on this old stuff.
Re: exploded 8 1/4 SureGrip view? [Re: MonGoo$e] #512757
11/01/09 08:09 PM
11/01/09 08:09 PM
Indiana
MonGoo$e Offline OP
MonGoo$e  Offline OP
Indiana
2
Re: exploded 8 1/4 SureGrip view? [Re: MonGoo$e] #512758
11/01/09 08:12 PM
11/01/09 08:12 PM
Indiana
MonGoo$e Offline OP
MonGoo$e  Offline OP
Indiana
3
Re: exploded 8 1/4 SureGrip view? [Re: MonGoo$e] #512759
11/01/09 08:14 PM
11/01/09 08:14 PM
Indiana
MonGoo$e Offline OP
MonGoo$e  Offline OP
Indiana
Re: exploded 8 1/4 SureGrip view? [Re: MonGoo$e] #512760
11/01/09 08:15 PM
11/01/09 08:15 PM
Indiana
MonGoo$e Offline OP
MonGoo$e  Offline OP
Indiana
Re: exploded 8 1/4 SureGrip view? [Re: MonGoo$e] #512761
11/01/09 08:16 PM
11/01/09 08:16 PM
Indiana
MonGoo$e Offline OP
MonGoo$e  Offline OP
Indiana
Lastly, 6
Re: exploded 8 1/4 SureGrip view? [Re: MonGoo$e] #512762
11/01/09 08:21 PM
11/01/09 08:21 PM
Indiana
MonGoo$e Offline OP
MonGoo$e  Offline OP
Indiana
Part number on the snout next to where the bearing would be is 18-05-039-903 which seems to be the same number I'm finding on ebay like that one posted (except they had another "0" in the number (18-005-039-903) maybe a typo, and identical to some others on ebay claimed to be at the latest, early 1980's.
