Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper
[Re: Rhinodart]
#512604
12/08/12 12:35 PM
12/08/12 12:35 PM
Posts: 2,212 Minnesota
peabodyracing
Minnesota
Hope you get it figured out soon. I can imagine how anxious you are to hear it run. By now I think I'd have been slipping in a point style distributor and hot wiring it just to make some noise while you wait for the wiring diagram. Possibly you know someone who deals in ignition parts?
Lead, follow or get the hell out of the way
[Re: Joesixpack]
#512606
08/30/13 05:10 PM
08/30/13 05:10 PM
Posts: 11,912 APACHE JUNCTION AZ
Joesixpack
APACHE JUNCTION AZ
8/30/2013 IT LIVES! RT66 Racer Mart B came by this morning and wired the MSD6C&Mallory coil...we filled the float bowls of the carb,hooked up a timing light.....hit the key and it roared to life...amazing sound....a few minor leaks(trans cooler lines,rad cooler line fitting,duh,tightened them up, hooked up the timing light,moved the dist a bit..., 1 minor fuel leak at float bowl screw(gasket delaminated,time to get nylon),and a few minor carb adjustments...sputter and dies....mechanical fuel pump needed to be primed...dropped line from pump to tank, back filed line with gas, reattached line, fired up and finallly gas flowed. warmed it up,no more trans leaks.no fuel leaks, no anti freeze leaks...its a great day!
[Re: CHAPPER]
#512610
09/01/13 09:16 AM
09/01/13 09:16 AM
peabodyracing
Minnesota
Way to go Bill! Congratulations.
