How important is a cam button?
#511851
10/30/09 09:09 PM
10/30/09 09:09 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
I know they help keep the cam from walking, and are really important with roller-cams. How important are they with a sizeable solid flat-tappet? (in a BB)
Re: How important is a cam button?
[Re: Quicksilver440]
#511854
10/30/09 09:17 PM
10/30/09 09:17 PM
Posts: 902 Mopar Lane,Mississippi
67HEMI
The lobes on a flat tappet cam are ground at a slight angle. The lifters keep the cam pulled rearward.
'33 Plymouth 5 Window Coupe Blown Aluminum HEMI w/bolt ons (under construction)
'69 Chrysler 300 Convertible 375 HP 440
'71 Plymouth Duster 360 W/EFI (Wife's Ride)
'12 Ram MegaCab Dually 6.7 Cummins
[Re: 67HEMI]
#511855
10/31/09 02:14 AM
10/31/09 02:14 AM
StealthWedge67
Puyallup, WA
Makes sense to me, thanks guys!
[Re: tjmarcus1]
#511862
11/01/09 12:05 PM
11/01/09 12:05 PM
Posts: 8,647 ELYRIA,OH
blownzoom440
ELYRIA,OH
PUT ONE IN! better to have and not need than to need and not have.
it will help the life of the timing chain in general keeping it more in line.i use the solid aluminum button.
[Re: sg66mopar]
#511864
11/10/09 09:51 PM
11/10/09 09:51 PM
Posts: 3,410 Belpre,Ohio
CHAPPER
Belpre,Ohio
I don't like the torrington bearing style cam button. Have had them fail/come apart. Those little rollers play havoc with oil pumps. I use the nylon type..Comp Cam.
If you like drag racing, support your local track.
[Re: CHAPPER]
#511866
11/10/09 10:21 PM
11/10/09 10:21 PM
Posts: 10,013 Frostbitefalls MN (Rocky&Bullw...
gregsdart
A lot depends on the individual situation, from my experience. When I first went to a rollercam, I didn't know any better and ran without a button. No problems. I WAS LUCKY The next motor needed one, and It didn't require a lot of effort to keep all the parts happy. I sold that good shortblock, (bad move) and built a mega block motor. That one has so much forward thrust, it pushed a reenforced cover out of shape so far it was .010 from crashing into the adjoining lobes! I put a milodon geardrive on it to give it a very stiff thrust setup, and it started to eat the surfaces so bad I now have it drilled and tapped for a direct oil feed through the cover to the button. That provides enough lube so it hasn't eaten the parts anymore than it had. No one can explain to me why this motor does this. It has bushed lifter bores, which should eliminate problems, I would think. So, I am all in favor of using a thrust button. For a test just pull the distributor, crank the motor for quite a few revolutions with the valve train in place and see what it does. If it moves the cam forward at all, better figure out how to address that. You want zero movement, or very close to it. Especially if you run a stock type distributor, no crank trigger.
[Re: gregsdart]
#511867
11/10/09 11:36 PM
11/10/09 11:36 PM
StealthWedge67
Puyallup, WA
Glad I re-visited this post. All good info, they're pretty cheap.... Why NOT put one in?!
