How important is a cam button? #511851
10/30/09 09:09 PM
10/30/09 09:09 PM
Puyallup, WA
StealthWedge67 Offline OP
Puyallup, WA
I know they help keep the cam from walking, and are really important with roller-cams. How important are they with a sizeable solid flat-tappet? (in a BB)
Re: How important is a cam button? [Re: StealthWedge67] #511852
10/30/09 09:13 PM
10/30/09 09:13 PM
Richmond Va, KeislerTKO 60...
V
VanishPt Offline
VanishPt  Offline
V
do not need one at all. The cam will keep itself in place
Re: How important is a cam button? [Re: VanishPt] #511853
10/30/09 09:14 PM
10/30/09 09:14 PM
Central Valley, CA.
Quicksilver440 Offline
Central Valley, CA.
Cam buttons are only used with roller cams....you dont use them with a solid flat tappet.
Re: How important is a cam button? [Re: Quicksilver440] #511854
10/30/09 09:17 PM
10/30/09 09:17 PM
Mopar Lane,Mississippi
67HEMI Offline
67HEMI  Offline
The lobes on a flat tappet cam are ground at a slight angle. The lifters keep the cam pulled rearward.
'33 Plymouth 5 Window Coupe Blown Aluminum HEMI w/bolt ons (under construction) '69 Chrysler 300 Convertible 375 HP 440 '71 Plymouth Duster 360 W/EFI (Wife's Ride) '12 Ram MegaCab Dually 6.7 Cummins
Re: How important is a cam button? [Re: 67HEMI] #511855
10/31/09 02:14 AM
10/31/09 02:14 AM
Puyallup, WA
Puyallup, WA
Makes sense to me, thanks guys!
Re: How important is a cam button? [Re: StealthWedge67] #511856
10/31/09 11:17 AM
10/31/09 11:17 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I've seen guys put them on solid cams just because! I never thought it needed but if I ever go back to a solid cam I may use one why not! Local builder here has brass ones made up he puts on all solid motors he assembles??
Re: How important is a cam button? [Re: StealthWedge67] #511857
10/31/09 02:26 PM
10/31/09 02:26 PM
Az
Crizila Offline
Crizila  Offline
Az
I learned the hard way on my max wedge motor. PUT ONE IN!!! Yes, the lobs are supposed to be cut so as to push the cam towards the back of the block. (the key to that sentence is "supposed") They are cheap, easy to install, you can now get one rollerized, and cheap insurance. Just had a friend go through this with a 496 motor. Name brand flat tappet cam - bounced in and out enough to just be audible. He caught it before it got ugly. Don't take a chance.
Fastest 300
Re: How important is a cam button? [Re: Crizila] #511858
10/31/09 02:38 PM
10/31/09 02:38 PM
Peoples republic of clackamas ...
atoetly Offline
atoetly  Offline
I'm running one on my flat tappet cam. But my setup is way different than most as I am running a set of composite mushroom lifters and some of the cam lobes had to be narrowed to make this work. If the cam ever decided to move forward I would have a bunch of broken parts so for the little money one cost I put one in.
Re: How important is a cam button? [Re: atoetly] #511859
10/31/09 02:46 PM
10/31/09 02:46 PM
sc
tjmarcus1 Offline
tjmarcus1  Offline
sc
PUT ONE IN! better to have and not need than to need and not have.
Re: How important is a cam button? [Re: tjmarcus1] #511860
11/01/09 12:00 PM
11/01/09 12:00 PM
sg66mopar Offline
sg66mopar  Offline
I ran this whole season, a little over 200 passes, with no cam button on my Comp roller cam. The motor's coming apart today. We'll see how much damage there was from this error in judgement.
Re: How important is a cam button? [Re: atoetly] #511861
11/01/09 12:02 PM
11/01/09 12:02 PM
sg66mopar Offline
sg66mopar  Offline
Same starting line, same lane.
Re: How important is a cam button? [Re: tjmarcus1] #511862
11/01/09 12:05 PM
11/01/09 12:05 PM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
it will help the life of the timing chain in general keeping it more in line.i use the solid aluminum button.
Re: How important is a cam button? [Re: sg66mopar] #511863
11/10/09 09:13 PM
11/10/09 09:13 PM
sg66mopar Offline
sg66mopar  Offline
Finally got my timing cover off today. There are some very light marks on the inside of the timing cover from the cam bolts touching it occasionally. I think the biggest problem is the slop in the chain, way more that it should be from only 200 passes. I'm sure the front/back movement contributed to the wear. For the most part the cam is pulled to the rear by the distributor gear resistance. All that being said, it'll have a cam button from now on!
Re: How important is a cam button? [Re: sg66mopar] #511864
11/10/09 09:51 PM
11/10/09 09:51 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
I don't like the torrington bearing style cam button. Have had them fail/come apart. Those little rollers play havoc with oil pumps. I use the nylon type..Comp Cam.
If you like drag racing, support your local track.
Re: How important is a cam button? [Re: CHAPPER] #511865
11/10/09 10:20 PM
11/10/09 10:20 PM
sg66mopar Offline
sg66mopar  Offline
Nylo sounds like the best way to go. Thanks
Re: How important is a cam button? [Re: CHAPPER] #511866
11/10/09 10:21 PM
11/10/09 10:21 PM
gregsdart Offline
gregsdart  Offline
A lot depends on the individual situation, from my experience. When I first went to a rollercam, I didn't know any better and ran without a button. No problems. I WAS LUCKY
The next motor needed one, and It didn't require a lot of effort to keep all the parts happy. I sold that good shortblock, (bad move) and built a mega block motor. That one has so much forward thrust, it pushed a reenforced cover out of shape so far it was .010 from crashing into the adjoining lobes! I put a milodon geardrive on it to give it a very stiff thrust setup, and it started to eat the surfaces so bad I now have it drilled and tapped for a direct oil feed through the cover to the button. That provides enough lube so it hasn't eaten the parts anymore than it had. No one can explain to me why this motor does this. It has bushed lifter bores, which should eliminate problems, I would think. So, I am all in favor of using a thrust button. For a test just pull the distributor, crank the motor for quite a few revolutions with the valve train in place and see what it does.
If it moves the cam forward at all, better figure out how to address that. You want zero movement, or very close to it. Especially if you run a stock type distributor, no crank trigger.
Re: How important is a cam button? [Re: gregsdart] #511867
11/10/09 11:36 PM
11/10/09 11:36 PM
Puyallup, WA
Puyallup, WA
Glad I re-visited this post. All good info, they're pretty cheap.... Why NOT put one in?!
