max wedge heads??? #511701
10/30/09 04:04 PM
10/30/09 04:04 PM
Indiana
79_W200 Offline OP
79_W200  Offline OP
Indiana
How much HP can a set of original max wedge heads make with porting. What besides the yearly 4 bolt valve cover and rocker pedestals should be avoided. I think the part number of the heads im looking for is 518 or are there others? I thought of going to indy -1's but i would like to keep stock heads. Thanks for any input
1979 W200 470
Re: max wedge heads??? [Re: 79_W200] #511702
10/30/09 04:05 PM
10/30/09 04:05 PM
AndyF Offline
AndyF  Offline
Original heads cost a ton. Maybe buy the Mopar Performance reproduction heads and have them ported?
Re: max wedge heads??? [Re: AndyF] #511703
10/30/09 04:08 PM
10/30/09 04:08 PM
Indiana
79_W200 Offline OP
79_W200  Offline OP
Indiana
They make a max wedge reproduction head? I am running a set of 915 that are ported but i would like to get some more power.
1979 W200 470
Re: max wedge heads??? [Re: 79_W200] #511704
10/30/09 04:37 PM
10/30/09 04:37 PM
Indiana
MFR426 Offline
MFR426  Offline
Indiana
Part # P5249824
We have them on our car and run 10.70's with a 63 Max Wedge intake and 440 block. The car is 3500LBS.
Good Luck!
MFR426
Re: max wedge heads??? [Re: 79_W200] #511705
10/30/09 08:48 PM
10/30/09 08:48 PM
AndyF Offline
AndyF  Offline
Yep. Add a P4876337 intake manifold and you'll have a nice top end. Have someone like Dwayne at Porter Racing Heads do the heads for you. He knows how to make those cast iron heads work.
Re: max wedge heads??? [Re: AndyF] #511706
10/30/09 08:54 PM
10/30/09 08:54 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
MW heads?
Floyd Lippencott IV
Re: max wedge heads??? [Re: 79_W200] #511707
10/30/09 11:21 PM
10/30/09 11:21 PM
AndyF Offline
AndyF  Offline
Here is a 440 with the MP max wedge heads and the 337 intake. This is a pretty nice combo really for a cast iron head setup. The 337 intake has a built in valley plate so everything is sealed up. The 337 intake works pretty well with a 4150 carb or you can run an adapter for a 4500 series.
Re: max wedge heads??? [Re: AndyF] #511708
10/31/09 06:03 AM
10/31/09 06:03 AM
Indiana
79_W200 Offline OP
79_W200  Offline OP
Indiana
What was the engine combination and what kind of power did it make? I am running a 470(400). MP doesn't make that manifold for low deck do they?
1979 W200 470
Re: max wedge heads??? [Re: 79_W200] #511709
10/31/09 10:16 AM
10/31/09 10:16 AM
AndyF Offline
AndyF  Offline
You are out of luck for a low deck motor. There isn't a MW intake made that will work with the factory heads on a low deck. You could use an Indy low deck intake and then weld in a valley tray but that is about it.
