lifter noise question #511334
10/30/09 09:15 AM
10/30/09 09:15 AM
San Angelo, Texas, U.S.A.
1968RR Offline OP
1968RR  Offline OP
I know that there aren't a lot of you using hydraulic lifters, but I figured that this was the best place to post this question...
I recently put a new cam in my engine (it's the Comp XE-HL .564" lift hydraulic grind) and went with Comp's Pro Magnum flat-tappet lifters. Ever since I fired the motor for the first time, I've been getting a lot of valve train noise. I've checked to make sure I have the correct pre-load three times now, and everything checks out. Nothing was changed other than the cam and lifters.
Are the Pro Magnum hydraulic lifters typically that much noisier than Comp's regular lifters?
"When I'm in a slump, I comfort myself by saying if I believe in dinosaurs, then somewhere, they must be believing in me. And if they believe in me, then I can believe in me." - Mookie Wilson
Re: lifter noise question [Re: 1968RR] #511335
10/30/09 09:28 AM
10/30/09 09:28 AM
Danville, NH
Mopar_Mike Offline
Mopar_Mike  Offline
Danville, NH
Did you break-in the cam correctly? With fresh oil, lube, run time, etc.
RS23L7 4-Speed
Re: lifter noise question [Re: Mopar_Mike] #511336
10/30/09 09:36 AM
10/30/09 09:36 AM
1968RR Offline OP
1968RR  Offline OP
I used Comps break-in lube and their break-in oil additive along with Valvoline's race 20W-50 race oil. The cam has about 1 hour of operating time on it (including 20 minutes break-in time), and I'm planning on changing out the oil this weekend. The cam doesn't seem to be going flat...
Re: lifter noise question [Re: 1968RR] #511337
10/30/09 09:45 AM
10/30/09 09:45 AM
Norway (old world)
Oyvind Mopar Offline
Norway (old world)
Could be your valvesprings are too stiff. Depends on what cam you had before, and the belonging springs...
Re: lifter noise question [Re: 1968RR] #511338
10/30/09 09:58 AM
10/30/09 09:58 AM
What method did you set the preload with? Those lifters have different setting procedure than the normal ones, try 1/8 to 1/ 4 preload instead of .002 lash
Re: lifter noise question [Re: Cab_Burge] #511339
10/30/09 10:10 AM
10/30/09 10:10 AM
Eagleville Tn.
rtstreet Offline
rtstreet  Offline
Eagleville Tn.
cam and lifters are not what they used to be
Re: lifter noise question [Re: rtstreet] #511340
10/30/09 10:53 AM
10/30/09 10:53 AM
1968RR Offline OP
1968RR  Offline OP
The springs are whatever Indy put on my heads before they shipped. The receipt has "911" on it (indicating Comp #911 springs, I guess), but they're double springs, so I don't know exactly what they are. Indy claims they're good to .650" lift. The previous cam was the Comp XE-HL .545" lift grind.
I set pre-load by going 1/4 turn beyond zero lash.
Re: lifter noise question [Re: 1968RR] #511341
10/30/09 11:48 AM
10/30/09 11:48 AM
Alberta, Canada
451Guy Offline
451Guy  Offline
Alberta, Canada
I have the same issue with my street car. Hyd Cam and Eddy Alum Heads. I have wondered if as the heads heat it effects the lash but you would think a hyd lifter would compensate for that to a point. I will watch this post with interest. Hopefully, someone will have the answer we both need. I am thinking about putting in a solid. If I am going to have the racket I may as well reap the benefits of the solid.
Thanx 451 Guy
512 cu in 71 Demon Super Street Car - NO LONGER - Broke Crank
Best ET 9.57 @ 139.96
451 cu in Pump Gas - 71 Demon Super Street Car
Best ET 9.99 @ 136.80
512 cu in 69 Charger R/T
Best ET 11.39 @ 118.11
Re: lifter noise question [Re: 451Guy] #511342
10/30/09 12:46 PM
10/30/09 12:46 PM
Hunt Valley, Maryland
1fastrunner Offline
1fastrunner  Offline
My new build has the same sound. I could never find the cause or reason, but people have told me not to worry about it. I've now got about 1,000 miles with no problems so far.
Re: lifter noise question [Re: 1fastrunner] #511343
10/30/09 12:56 PM
10/30/09 12:56 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
with aluminum heads 1/4 turn (.010) of pre load is not enough. should have been 1/2 to 3/4 iron heads and 3/4 to 1 aluminum? I would add 1/2 turn pre load and if it still ticks 1/4 turns till it is gone.
Re: lifter noise question [Re: 1fastrunner] #511344
10/30/09 01:03 PM
10/30/09 01:03 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
My Eddy-headed 446" RB made valvetrain noise, fairly fresh motor, after I'd tightened the valve cover fasteners a bit. Turned out to be a few rocker arms tapping on the valve cover baffles and the rocker stand clamps coming in contact with the valve covers and transferring sound. It was the stands at front & rear. A few minutes scientifically clearancing the baffles with a punch & hammer (protect the outside of the covers) and filing the outside corners of the stands cured it.
If that's not it, try another 1/8 turn on the preload, though I've never run more than 1/2 turn.
This assumes your geometry & pushrod length are correct.
20W-50 is a bit heavy for my tastes on anything less than 200,000 miles or below 40 degrees F air temp.
Re: lifter noise question [Re: 1968RR] #511345
10/30/09 03:35 PM
10/30/09 03:35 PM
closer to Canadian beer!
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
I think the pro magnums are a little noisier. If I recall correctly they use less pre-load than the Hi Energy lifters.
