lifter noise question
#511334
10/30/09 09:15 AM
10/30/09 09:15 AM
Posts: 1,943 San Angelo, Texas, U.S.A.
1968RR
I know that there aren't a lot of you using hydraulic lifters, but I figured that this was the best place to post this question... I recently put a new cam in my engine (it's the Comp XE-HL .564" lift hydraulic grind) and went with Comp's Pro Magnum flat-tappet lifters. Ever since I fired the motor for the first time, I've been getting a lot of valve train noise. I've checked to make sure I have the correct pre-load three times now, and everything checks out. Nothing was changed other than the cam and lifters. Are the Pro Magnum hydraulic lifters typically that much noisier than Comp's regular lifters?
"When I'm in a slump, I comfort myself by saying if I believe in dinosaurs, then somewhere, they must be believing in me. And if they believe in me, then I can believe in me." - Mookie Wilson
Re: lifter noise question
[Re: 1968RR]
#511335
10/30/09 09:28 AM
10/30/09 09:28 AM
Posts: 4,288 Danville, NH
Mopar_Mike
Danville, NH
Did you break-in the cam correctly? With fresh oil, lube, run time, etc.
RS23L7 4-Speed
[Re: Mopar_Mike]
#511336
10/30/09 09:36 AM
10/30/09 09:36 AM
1968RR
I used Comps break-in lube and their break-in oil additive along with Valvoline's race 20W-50 race oil. The cam has about 1 hour of operating time on it (including 20 minutes break-in time), and I'm planning on changing out the oil this weekend. The cam doesn't seem to be going flat...
[Re: rtstreet]
#511340
10/30/09 10:53 AM
10/30/09 10:53 AM
1968RR
The springs are whatever Indy put on my heads before they shipped. The receipt has "911" on it (indicating Comp #911 springs, I guess), but they're double springs, so I don't know exactly what they are. Indy claims they're good to .650" lift. The previous cam was the Comp XE-HL .545" lift grind. I set pre-load by going 1/4 turn beyond zero lash.
[Re: 1968RR]
#511345
10/30/09 03:35 PM
10/30/09 03:35 PM
Posts: 2,715 closer to Canadian beer!
torkrules
I'm neurotic
I'm neurotic
I think the pro magnums are a little noisier. If I recall correctly they use less pre-load than the Hi Energy lifters.
