Paint Q: Source for PSA Backing Pad w 5/8 Female hole ? #511262
10/30/09 01:51 AM
10/30/09 01:51 AM
Culberson, NC
Chargerbee Offline OP
Culberson, NC
I have an adjustable speed polisher/grinder and also an adjustable speed grinder and both have a 5/8-11 arbor that I would like to use them to do some sanding and paint removal.
I have a ton of Self Adhesive Discs(PSA and non-PSA as well) and I need to find a 5" or 6" backing pad with a 5/8" female hole. Finding these with a 1/4 male is no problem, finding them with a 5/16" is no problem, but neither of those do any good.
Can anyone point me in the direction of a place that sells such an item ? I've tried the websites of Grainger, Fastenal, Milwaukee, Bosch, Makita, Dewalt, and have not had any luck. They sell a backing pad that is meant to be used with those sanding discs with a hole in the middle.
I'm pretty desperate to find something, so leads are appreciated.
Re: Paint Q: Source for PSA Backing Pad w 5/8 Female hole ? [Re: Chargerbee] #511263
10/30/09 12:27 PM
10/30/09 12:27 PM
Doo-Dah, KS
440fied Offline
440fied  Offline
Doo-Dah, KS
You might try 3M they make a bunch of different backup pads for buffers, grinders and random orbital sanders. Here is a link to their backup discs for grinders/buffers in the industrial and manufacturing section of their website.
3M grinder/buffer backup pads
They have a listing for a 5 inch pad that is 1/2 inch thick and attaches with a 5/8-11 internal(female) thread and uses PSA discs, but they only sell them in packs of 5 or 10.
they also have a listing for a 5 inch pad that is 3/4 inch thick
You might cross reference their UPC codes or 3M codes at grainger etc... or google them and see if anyone sells them in singles. Hope this helps.
on a side note I have used a friends 7 inch buffer from that he got from harbor freight, it uses hookit style sanding discs that they also sell, to remove paint from body panels.
http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=92623
you might try ordering a replacement backing pad from them and peel the hookit material off and file it down to 5 inch or 6 inch diameter, it uses a 5/8-11 female thread to attach to the arbor.
Re: Paint Q: Source for PSA Backing Pad w 5/8 Female hole ? [Re: Chargerbee] #511264
10/30/09 09:03 PM
10/30/09 09:03 PM
Culberson, NC
Culberson, NC
I love you man. Thank you so doggone much.
THANKS !
Re: Paint Q: Source for PSA Backing Pad w 5/8 Female hole ? [Re: Chargerbee] #511265
10/31/09 12:25 AM
10/31/09 12:25 AM
Doo-Dah, KS
440fied Offline
440fied  Offline
Doo-Dah, KS
No problem, just helping out.
Re: Paint Q: Source for PSA Backing Pad w 5/8 Female ho [Re: Chargerbee] #511266
10/31/09 02:55 PM
10/31/09 02:55 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
These guys have lots of them and other good buffing stuff too...
http://www.autogeek.net/backingplates.html
